Page 28 of 50 FirstFirst ... 2627282930 ... LastLast
Results 271 to 280 of 498
Thread: Outback Ideas Recovery points
  1. #271
    Quote Originally Posted by Drewboyaus View Post
    So if that's how they attach, then the left hand side should have captive nuts in place on the barwork so you'll be able to use the standard GQ plates but may need longer bolts.
  2. #272
    Oct 2011
    Essendon
    That is what I hope will happen. There are only 2 bolts used for securing the bar on the LHS so I'm hoping that is enough......I would think it should be.
  3. The Following User Says Thank You to Drewboyaus For This Useful Post:
    BigRAWesty (28th September 2013)
  4. #273
    Having said that though, those holes are in a different orientation to the ones on the right hand rail. Did the have to droll those holes in the left rail, or were they already there?
    Mine were already there but the mirror image to the right side.
  5. #274
    Oct 2011
    Essendon
    All the holes were already there and ARB supplies the mounting plates that slide down inside the chassis rail.
    I think you'll find the positioning of the two holes on the LHS is the same as two of the holes on the RHS but there is a third on the RHS that could be drilled on the left but would need a nut in the inside of the chassis and I'll be buggered if I'm pulling the winch and bar off again to do it.
  6. #275
    Like so........ Fit TD's plate to the left side rail with the aid of a captive nut plate from patrol apart.
    Right side
    As you can see my bar attaches to the inside edges of the chassis rail not through the inside.
  7. #276
    Oct 2011
    Essendon
    Right side
    That still means I need to pull the bar off to slide the captive nut plate down the chassis rail though.
  8. The Following User Says Thank You to Drewboyaus For This Useful Post:
  9. #277
    now I've jumped on the lappy I can see your photos properly and understand what you mean
  10. The Following User Says Thank You to Clunk For This Useful Post:
    Drewboyaus (28th September 2013)
  11. #278
    Yes, yes you will.. I'd pull the drivers side out and make a mirror image for the passenger side..
    Also make them all the same bolts..
    For some reason mine are different..
    Oct 2011
    Essendon
    No. No I won't. LOL
    I have zero intention of pulling the bar off. I have many more useful (or frivolous) things to do with my time than that. That LHS will either go on with 2 bolts or not at all.
  13. #280
    No. No I won't. LOL
    I'm with you.. It should be ok with 2. I'll be doing mine soon so if you guys want a set give us a yell..
