Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: my nissan wont start
    Feb 2011
    atherton tablelands
    Angry my nissan wont start
    my name is nathan and i bought a ti 4.2 gq wagon and now it wont start. it has spark plenty of fuel and injector pulse,whats going on with it? could it be a coolant temperature sensor or similar?
    How much fuel pressure and flow does it have, and how old is the petrol? Has any other work be done to the car lately before this happened?
    Tony
    Feb 2011
    atherton tablelands
    Question faulty sensors
    can a faulty sensor cause my nissan to not start. my car will turn over but wont start unless i block fuel line and give it full throttle to start. efi engines should need no throttle to start but mine wont start without it.does the coolant temp sensor control the ammount of fuel injected into engine and how do i check for faults in sensors without an auto electrician?
    Feb 2011
    atherton tablelands
    fuel pressure seems to be ok, the fuel is new. the only way i can start it is to block fuel line and give it full throttle while winding.once started i unblock fuel line and it runs.
  5. #5
    Which fuel line are you blocking? If it's the return line then that suggests you may have a faulty fuel pressure regulator or fuel pump causing low fuel pressure.
    Tony
  6. #6
    Feb 2011
    atherton tablelands
    the line just before fuel filter
  7. #7
    Feb 2011
    atherton tablelands
    will a scanner identify fuel pressure problems
  8. #8
    No a scanner will not properly identify a fuel pressure problem, you need a gauge for that. If you are having to block the main fuel line (reducing fuel to engine) and use full throttle, that suggests the computer is trying to inject too much fuel. There are a number of things that could cause that. Faulty coolant temp sensor, faulty airflow meter etc.
    Tony
  9. #9
    Feb 2011
    atherton tablelands
    sorry for posting new threads,im only new to this and am finding it hard to get the info i need.
  10. #10
    Feb 2011
    atherton tablelands
    would there be an easy way to check coolant temp sensor?
