Results 1 to 10 of 10
Thread: Gearbox crossmember bolts
    Expert florix's Avatar
    Casino
    Hey people.
    Does anybody know the specs of the gearbox crossmember bolts for a GU? Better yet do you know where I can get some? Nissan stated they are $35 trade each!
    That is a silly price! Sorry can't help with a price or size. Take 1 out and take it in for sizing. Trust me your gear box won't fall out if you take one out
    I'm pretty sure there m12 metric fine 40mm long
    I'll go check
    M12 metric fine, 50mm long..
    Make sure to get zinc plated..
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
    MudRunnerTD (27th September 2013)
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    But are GQ and GU the same????
    Yes I would expect so
    x2. the use the same chassis. but easy to put a tape on them
    Casino
    Yeah I have two out already. Lol.
    Thanks mate now I can go on the hunt.
    Oh and yes. GQ and GU are the same. It's just a for of habit so I am specific. Will go one better and state nissan wanted to know yeah and engine... Didn't think they made different bolts for different engines lol
  10. #9
    Hardcore
    central coast nsw
    My DA Maverick manual has ( in a chart ) bolt sizes and strengths associated with various size bolts.
    have a look see in your manual see if ya can find similar.
    Also bolt grade numbers (example, 8 ) is usually stamped on end of a hi tensile bolt.
    Oh! and never substitute to a lower number.
    take a bolt with you to make sure you get the correct pitch.
    thats the amount of threads per mm
    1, 1.25, 1.5 threads per mm etc
    cheers
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  11. #10
    Nov 2013
    120-140Nm according to the workshop manual.
    The rear Uni joint nuts on the driveshaft are 94-108Nm in case you need this as well.
