Page 58 of 177 FirstFirst ... 5657585960 ... LastLast
Results 571 to 580 of 1768
Thread: Ask all your general ( none related forum ) computer questions here
  1. #571
    Feb 2011
    Shed
    45 Post(s)
    I've pressed restore to see what'll happen so fingers crossed.............
    Is smoke meant to come out??
  2. #572
    Your arse or your computer??????
  3. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    Avo (18th August 2013), NissanGQ4.2 (18th August 2013)
  4. #573
    Oct 2011
    Essendon
    What O/s are you using and what brand and model printer is it? I'm guessing your printer, it has a dynamic IP address which takes it offline when it cycles through its IP addresses, and is not being seen by the network. You will need to get into the settings of the printer and manually set the IP address of the printer. How? depending on the printer but usually there will be a settings tab and find an option that may say sometihng like "choose or setup up network". It will be in there somewhere.
    There is an option somewhere in your setting to print off the network settings, which will show what IP address is currently being used. Then use that as your permanent IP address when you go into the network settings.
    X 2.
    I will probably be because the automatic IP address leased to it via the DHCP server in your router has a problem when your printer goes into standby.
    I would definitely be reading the manual and allocating a static IP address to the printer (via printer settings). Make sure you set it beyond the IP range of the DHCP table in your router (modem).
    Post up your printer and router model and I'll see how I go stepping you though the process.
    Tip tip tip......tap tap tap....
  5. #574
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    OK so i downloaded a manual and i got a pop up saying that my Win Zip was expired and would i like to purchase it. Well i must have originally just got a trial version from somewhere when i downloaded the gq manual last year. So what do i do? I dont wanna pay for dat sh1t! Ill more than likely only use it once in the next year or so.
    Is there anyway to unZip the GU manual without purchasing WinZip???
    (Ive got good, fast internet so i reckon it wouldnt take long to download an unzipped file if one was available)
    Hello from Under Down Under!
  6. #575
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
  7. The Following User Says Thank You to Bob For This Useful Post:
    taslucas (25th September 2013)
  8. #576
    lucas,
    use 7zip or winrar. winrar supposedly expires but it never actually stops working, just reminds you you should pay for it occasionally. both programs are way better than winzip.
    nic
  9. The Following User Says Thank You to rusty_nail For This Useful Post:
  10. #577
    7zip Lucas.....Then you can make and extract RAR files, way better then winzip and zip files.
    I can compress 200mb 3dmax files down to about 10mb.
  11. The Following User Says Thank You to AB For This Useful Post:
  12. #578
    7zip IS great, only gripe i have with it is i find the GUI less userfriendly than winrar. 7zip does accept more file types though... =)
  13. The Following User Says Thank You to rusty_nail For This Useful Post:
  14. #579
    Don't bother. Why do you need a GU manual anyway?
  15. #580
    .......... TPC's Avatar
    63 Post(s)
    Have you seen the light and decided to buy a GU?
