Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 56
Thread: The crazy mod idea thread
    Patrol Guru SonOf's Avatar
    Dover, Tasmania
    Maybe a good mod would be to insatll a stainless tank in the engine bay and run some 1/8 copper flex pip around the exhaust to heat water. Have a small pipe running into the cbin and a tap so you can make a cuppa on the run? If you worked out pressure ratings and had a release valve you could even adapt a coffee group head to make a good cup of joe.
    Seemed like a good idea at the time
  2. #22
    Brilliant ideas gents....lol
  3. #23
    You could run another Alternator via the Tail shaft, something like that
    Its turning so IMO has a lot of potential
  4. #24
    @ Sonof,,,,, Ben Dark did similar using radiator water through a copper coil inside a pot,
    Drove the Nullabor and his Stew was a throw away, didn't even get warm.
    Silver foil and rest them on the exhaust manifolds works Okish
  5. #25
    Patrol Guru rkinsey's Avatar
    Sep 2010
    Minchinbury
    U certainly know how 2 hurt a grown mans feelings.
    Going to go cry in the corner now
    I did use to use it, does that count for something?????????
    Hey Todd,
    You own a GQ...... 'nuff said!
    Just about to jump into my next Patrol. A 2001 GU II TB45E .
    WARNING!: Do not ever use a towball as a recovery point. They are not rated and can become a deadly projectile during a recovery if they snap off, and they have done so with tragic results in the past.
  6. #26
    Well I had a better look at it....Crap idea...lol.....Height won't fit, will stick out more than 100mm, will restrict leg room on passenger too much.
    Yes Winnie, I need to build the box around the fridge, I just can't be bothered...lol
    Especially with the baby 2 on the way and the Simpson trip will throw all my plans out the window with 2 x child seats needed.
  7. #27
    brisbane
    It would have to be fully sealed and a water cooled or it wouldn't last long if it was just standard. But good idea, wonder how it would go in reverse ?
  8. #28
    Perth WA
    63 Post(s)
    Well this thread wasted 5 minutes of my time....lol
  9. The Following 2 Users Say Thank You to Woof For This Useful Post:
    AB (24th September 2013), BigRAWesty (24th September 2013)
  10. #29
    Quote Originally Posted by The Dogman View Post
    It was fun though...lol
    Don't worry Doggy, I am sure another idea is just around the corner!!!
  11. The Following User Says Thank You to AB For This Useful Post:
    Woof (24th September 2013)
  12. #30
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by rkinsey View Post
    Hey Todd,
    Good to see you still around, did you end up selling your Patrol???
