Page 36 of 122 FirstFirst ... 3435363738 ... LastLast
Results 351 to 360 of 1220
Thread: October Meetup thread 11, 12, 13th Knockwood
  1. #351
    OK forgot you had custom mods under bonnet,
    could maybe hook up temporary one in the rear somehow if time allows
    Or just take a 100AH battery in a box that will charge via cig lighter.
    Not ideal but gives you power instead of using Start battery.
    I have a few of these lying around if it suits your needs, going super cheap
  2. #352
    Yeah I'm not too keen on having a battery in the back, I'd rather have it under the bonnet. I'll go get a quote next week for it and then I'll see ARB and the other shop in town and see what they recommend.
  3. #353
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Might be hard on the battery keeping up a two person supply of garlic balls
    Hello from Under Down Under!
  4. #354
    Dual batteries are overrated, dual alternators is where it's at.
  5. #355
    Aug 2011
    North West Tas
    56 Post(s)
    Yeah by the sounds of it you can heat up food in top of your battery
  6. #356
    22 Post(s)
    Well it is confirmed I am fitting up 3 inch springs to go with my shocks and also panhards.... should be completely different to the last trip out!!
    what spring rates are you going to get
    96 GQ coil/Cab
    08 G6eT
  7. #357
    Thomastown, Melbourne
    6 Post(s)
    Heavy in the rear and the front to suit bar and winch???
  8. #358
    22 Post(s)
    put it over the weighbridge and weigh the front half of the wagon you might only need mediums in the front
    96 GQ coil/Cab
    08 G6eT
  9. #359
    6 Post(s)
    To late they are ordered. .. with my super contacts I got them for $300...
  10. #360
    Oct 2011
    Essendon
    Which springs, OME?
