Will you be running a charger for both batteries?
If so run both of the cranking battery so the are both drawing raw voltage Off the alternator once the main cranking battery has charged.
But if you intend in running the trailer battery and aux battery off the same charger the run your cable from either the charger or the aux battery.
Any solar in the mix?
Also 6b&s?? What size mm is that?
