Just want to know what temp in Celsius they should run at Got aftermarket gauge with a calibrated temp sender
I think the patrols run a 85 or 86 degree thermostat..
Poodog (20th September 2013)
So is that a some what of a standed running temp? What would be the higher end of the scale as I don't mind a bit of right foot and I do a bit of towing.
I'd be getting worried if it rose to 120 deg
You running coolant ?
MY temp at this time of year is sitting at an average of 81-83 but when towing its sitting at about 85-86 and when doing a hill climb on a track it gets to nearly 90....... These figures will change as I have not run this set up for a full year yet.
Yer mate running coolant the gauge on the dash moves around abit in a short space of time on a reasonably flat road and I only but a new head on it last week just want To see what a new gauge reads
They run an 82 degree c thermostat. If it's a genuine one that is. Aftermarket might be different. But mine runs about the same as Bloodyaussie.
BigRAWesty (20th September 2013), Poodog (21st September 2013)
BigRAWesty (21st September 2013), Poodog (21st September 2013)
