Page 242 of 1057 FirstFirst ... 240241242243244 ... LastLast
Results 2,411 to 2,420 of 10566
  1. #2411
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    Quote Originally Posted by 93patrol View Post
    Retainer to stop your cab from lifting off
    Is it because there are less body mounts on the ute compared to the wagon?
  2. #2412
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    More than likely my utes got the same thing
  3. #2413
    This
    To this
    Gone
    Took it from 2600 tip to tail to just over 1950..
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Stropp (19th September 2013)
  5. #2414
    22 Post(s)
    Question
    Finished putting the winch together, I have an allbright solenoid on the way so I can wire it and then some rope.
    The brake assembly on the high mount is testing, I ended up using magnets under the brake which held the bearings in place, I used that spring loaded mechanism and a piece of plate to compress the spring then another clamp to hold the brake pack together while I put the circlip on.
    I also fitted it to the bull bar and wired in the spotties. I think it looks pretty mean now
    96 GQ coil/Cab
    08 G6eT
  6. #2415
    Looking good bene
  7. #2416
    Perth WA
    63 Post(s)
    Washed it with soapy stuff, 2nd time in 3 years
  8. #2417
    I did not realise you we're going tube bar, looks sweet as!
    Sent from my iPad using Motorculture mobile app
  9. #2418
    22 Post(s)
    I modified the old bullbar, it looked good on the bench when I put it on it looked like shite, I dont mind it if it looks ordinary, but this was shite, so I bought that bar off ebay
    96 GQ coil/Cab
    08 G6eT
  10. #2419
    Patrol Freak Rustyboner81's Avatar
    Perth
    what ya makin westy?
    '92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
    Lukey 2.5" Performance Exhaust with Extractors, snorkel
    Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
  11. #2420
    Cutting down the roof rack.. Was 2.6m long... That's longer than the q roof...
    So down to 1.9m..
