Results 11 to 20 of 41
Thread: Qld laws
    Heard from another member who just had his Patrol engineered that they will now measure height from the Door handle.
    Don't shoot the messenger
  2. #12
    Oct 2011
    Essendon
    Light bar will be fine as its not a driving light.. It's a work light.. You can have as many as you want.. As long as you stay within the limits of height, width and nothing past front of bull bar you will be right.
    As soOn as you wire into driving light system then you deal with pairs, etc..
    I don't believe this to be correct. A 12000 lumen lightbar is not a worklight. Every cop in the land will bust you for having a separately switched forward facing lightbar.
    If it was correctly wired in, you would be very unlucky to be done for having too many forward facing lights.
    Tip tip tip......tap tap tap....
  3. #13
    Quote Originally Posted by Drewboyaus View Post
    It's written black and white in the regs.. No limit on work lights.. I can't see how they could do you for it if not wired to lights..
    But I've never heard of anyone being done just for a light bar.. It's usually something bigger and then they start picking..
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    heard from another member who just had his patrol engineered that they will now measure height from the door handle.
    was there and saw the report
  5. #15
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Quote Originally Posted by roofy View Post
    How can they do that? Do they have a book of heights from manufacturer?? Or is it just a case of it looks to big therefore here's a fine.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  6. #16
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Quote Originally Posted by oncedisturbed View Post
    As Drew mentioned, it should be inline with VSB 14 across Oz
    hahahaha I don't think much is across oz when it comes to road regs
    How long ago was it that they started talking about a National Code????? Still waiting
  7. #17
    Oct 2011
    Essendon
    Exactly. If your ride looks reasonably clean and presentable with no obvious crazy lift and tyres the cops won't bother. +4inch lift and 35's is cop bait.
  8. The Following User Says Thank You to Drewboyaus For This Useful Post:
    threedogs (17th September 2013)
  9. #18
    How is that true? As they say lights on the front of the car need to be wired into your high beam circuit on a separate switch. Pretty sure work lights have to be rearward facing?
    I read it as any light wired into the high beam circuit has to be facing forward and wired threw a switch. So a work light can face award but wired separately.
    But I guess it's how they interpret it on the night..
    Expert janderson's Avatar
    Bearii Vic
    Here in Vic I believe you only allowed no more than 8 forward facing lights. Hi and lo beam are counted as separate. Have heard that some cops are counting every LED as a single light. Then booking you for having more than 8 forward facing lights.
    1st G60 Then MQ Now GU
  11. #20
    Oct 2011
    Essendon
    Quote Originally Posted by janderson View Post
    Good luck with that one in court. I reckon I could represent myself and beat that one!
    Thing is though, like was pointed out earlier if you keep it looking nice and tidy the cops are unlikely to pull you over in the first place.
  12. The Following User Says Thank You to Drewboyaus For This Useful Post:
