Results 1 to 10 of 13
Thread: Patrol wont start, nissan say its the air con pump?
    Expert Shaun 4x4's Avatar
    Secrets
    I have a 2005 zd30 auto patrol.
    The other day it wouldnt start. Not a battery problem as they are new.
    Checked all the leads and they are all tight.
    So sent it to nissan and they have told me its the air con pump needs replacing?
    How is this stopping my car from starting?
    If it is can i just disconnect it as i dont have a spare $1100 at the moment to replace the pump and belt that they say need replacing.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    If the A/C compressor has seized it can stop the engine from turning over.
    What was happening when it wouldn't start?
  3. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    Bloodyaussie (11th September 2013), threedogs (11th September 2013)
    It would need the clutch on the air con to be locked on for it to effect that.
    The outer of the clutch is always spinning and when you hit the ac button its energises the electomagnetic field inside and engages the comoressor drive shaft.
  5. The Following User Says Thank You to davo94 For This Useful Post:
    Col.T (11th September 2013)
    Secrets
    It sounded like it wanted to start but didnt have enough power to turn over.
    I spoke to nissan again and they have said that the pully is seized along with the pump.
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by davo94 View Post
    There is a bearing in the pulley in the front of the compressor that is common for failing.
    If this bearing has seized, having the A/C on or off will have no affect.
    The ECU also switches off the A/C during cranking.
  8. The Following User Says Thank You to Yendor For This Useful Post:
  9. #6
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by Shaun 4x4 View Post
    The bearing in the pulley is replaceable.
    If you can spin the inner part of the clutch plate by hand you might only need to replace the front bearing instead of the whole compressor.
  10. #7
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    You can do it yourself for 500 bucks bloke. Had this happen to me not long ago buy it second hand it's 4 bolts 2 pipes and a eletric plug. Get a genuine belt and ten get te system re gassed all under that price.
    Such is the rule of honour.
  11. #8
    Patrol Freak Rustyboner81's Avatar
    Perth
    Quote Originally Posted by macca86 View Post
    You can do it yourself, but not without breaking a bunch of laws. Its illegal to work on aircons without a license and if you release that refridgerant into the atmosphere dont post it on here!
    I suppose you cant take the aircon belt off or a smaller belt to bypass it on those engines?
    '92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
    Lukey 2.5" Performance Exhaust with Extractors, snorkel
    Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
  12. #9
    Secrets
    Cant take the belt of as it linked in with the main belt.
    That was my first question to them.
    Im just gonna get nissan to fix it and be done with it.
    Hopefully this is it for awhile, otherwise it might be bye bye time for the patrol
  13. #10
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Try an auto sparkie before using a dealer......
    1999 GU 4500 dual fuel
    Il dado è tratto
