Results 1 to 10 of 13
Thread: Catch can
    Sep 2013
    Sydney
    Catch can
    Hi, i have been advised that I should instal a catch can kit on my 2003 GUIII Patrol 3ltr auto. please advise if this is a good idea and what does this do for the engine. I have travelled 185000k and have never had a problem with the engine.
    Its always advised to instal a CC on any diesel. What a CC does is filter the engines crankcase vapours before it re enters the engine. Without a CC, the oily vapours re enter the engine before the turbo and oil up the turbo and intercooler. Same as blocking the EGR, this stops dirty exhaust gas from re entering the engine and eventually blocking the intake system.
    SEALEGEND (10th September 2013)
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    It's worse on the 3ltr as the recirculation pipe is before the maf sensor, so the oil mist coats it then gives false readings to the ecu and then bang, new motor is required.....
    Clean your maf too, it's an easy process and the procedure is on the forum in a thread.
    Cheers,
    Eric.
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
  5. The Following User Says Thank You to trekster For This Useful Post:
    Quote Originally Posted by trekster View Post
    Cheers,
    Eric.
    Correction Eric. Its after...It enters the intake between the MAF and before the turbo.
    Nov 2012
    Coffs Harbour, NSW
    Hmmm interesting, I swear I saw a pipe before on the zd30 in my inlaws car, I will need to take a better look next time!
    1998 GU RD28T: RIP
    Thats the snorkel mate
    Lionel84 (1st October 2013)
  10. #7
    Expert Limmy's Avatar
    I was surprised with how much oil was captured ! definitely worth the mod
  11. #8
    Nov 2012
    Coffs Harbour, NSW
    You're a wally hahaha, I will check it next time I get a chance lol.
    1998 GU RD28T: RIP
  12. #9
    Patrol Guru SonOf's Avatar
    Dover, Tasmania
    They are dead easy to make if you are handy with the tool otherwise ebay: http://www.ebay.com.au/itm/OIL-CATCH...ht_2839wt_1063
    Worth every cent compared to engine pop
    Seemed like a good idea at the time
  13. The Following User Says Thank You to SonOf For This Useful Post:
    SEALEGEND (12th September 2013)
  14. #10
    Sep 2013
    Sydney
    Hi All,
    have installed the catch can and an anti det kit. have ordered a 3" Taipan XP exhaust system to further improve the trucks running. has anyone else done a similar system and have they noticed any improvements.
