Results 1 to 10 of 24
Thread: 2003 GUIII. Let the wallet emptying modifications begin!! Sorry Mrs!!
Threaded View
  1. #14
    Yes, I would think once you take control of boost away from the ECU you should be fine.
    Need your gauges fitted first then as you fit /modify stuff you'll be able to monitor any changes
    cause is over boosting and going into limp mode
  2. The Following User Says Thank You to threedogs For This Useful Post:
    RCKIWI (9th September 2013)
