Page 13 of 16 FirstFirst ... 1112131415 ... LastLast
Results 121 to 130 of 156
Thread: our car
  1. #121
    Hardcore healy's Avatar
    south east melbourne victoria
    Ive decided to run the gu diffs on the new gq which radious arms do I use and will brake lines all match up
    IF ITS NOT BROKEN IT MUST BE A PATROL
  2. #122
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by healy View Post
    I believe brake lines will not be an issue
  3. The Following User Says Thank You to growler2058 For This Useful Post:
    healy (7th September 2013)
  4. #123
    Probably easier to just unbolt radius arms from the car and swap the lot. Direct fit of the brake lines.
    But swap the brake master cylinder to as the gu one will suit the gu brakes..
    But all will fit either way
  5. The Following User Says Thank You to BigRAWesty For This Useful Post:
  6. #124
    Same radius arms, you will need to steel the Tie Rod, the Drag Link and the Steering box too. Choose the radius arms that have the best Genuine a rubber Radius bushes in them. Not a big deal to unbolt but use the best you have.
    If either of the cars have Manual Hubs bolt them up as they fit either.
    When you undo the drive shaft it will want to roll back so get the radius bolts out first if you can.
  7. The Following User Says Thank You to MudRunnerTD For This Useful Post:
  8. #125
    Also got a snorkel for it should look nice
  9. The Following User Says Thank You to healy For This Useful Post:
    BigRAWesty (7th September 2013)
  10. #126
    us poms are crap at cricket fracster's Avatar
    North West England.
    Good to read that something is finally going right for you mate, best of luck.
    It is now official, we are not quite so sh@t at cricket as we were! Rugby Union is a different matter.
  11. The Following User Says Thank You to fracster For This Useful Post:
    PMC (8th September 2013)
  12. #127
    Hardcore
    Coffs Harbour
    Quote Originally Posted by fracster View Post
    You slut!
    You comment on everyone else's build and not mine!
    PS, i do have feelings. lol
    Regards,
    RLI
    The halls been rented the bands been paid, time to see you dance!
  13. #128
    Snorkel going on
  14. #129
    Good budget build here, 2 patrols for less than 15k....
    How much did the snorkel set you back.
  15. The Following User Says Thank You to nissannewby For This Useful Post:
    Winnie (12th September 2013)
  16. #130
    Hey Mat that is a Patroldoctor air box and snorkel. Pretty keen on one of those too. Looks good Healy.
  17. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    healy (12th September 2013)
