Page 235 of 1057 FirstFirst ... 233234235236237 ... LastLast
Results 2,341 to 2,350 of 10565
  1. #2341
    Advanced jackwalks's Avatar
    Warner, Brisbane
    Over the weekend just gone, I ripped out the following:
    1 - Dodgy wiring for my spot lights as they were cutting in-out whilst on and shorting out
    2 - Removed the old UHF antenna and unit as the antenna was cut in many places and re-attached over time from previous owners.
    3 - Removed the Pioneer double din gps unit as it was crap for off-road and map updates are a small fortune (+$300 for ’12 latest).
    Once I cleaned out old wiring & removed half the interior I installed:
    1 - New UHF antenna and unit. I have now got a compact unit, Uniden UH7700NB.
    2 - Rewired the spotlights with new ballast and wire loom.
    3 - Installed a single din Pioneer DEH-X6550BT and Pioneer rear door speakers.
    4 - Replaced my rear fake all red lights for some eBay specials, I just need to wire the drivers side (eventually).
    5 – Got some help to install my NADS – Boost, EGT, Pillar Pod, Catch can and blanking plate.
    6 – Installed a 22inch LED light-bar, and almost blinded myself in the process.
    7 - Also installed a bash plate, and about to buy a hardcase diff protector
    Overall, a busy weekend for me, but well worth it. Engine bay looks a lot tidier with no loose dodgy wires appearing, the interior is a little neater and more manageable for the wife.
    I also did my first minor service, changed the oil & air filter, used Penrite 15w50. Cleaned the MAF. I could not for the life of me get the fuel filter off – any tricks would be great.
    So far no oil leaks seen, so I must have done something right, lol
    Next on the cards is a DP chip, but I think I will get that installed professionally.
    2001 GU II - 3.0TD Auto. ARB Bullbar - Runva 11XP Winch - NADed with Boost & EGT gauges - OME 2in Lift - Manta 3in - Dual Battery - Spotties & LED Lightbar - Uniden 80ch UHF - Rear Drawers & Engel Fridge - 3/4 Steel cage Car goes vroom
  2. #2342
    22 Post(s)
    Finished the intake, put a flexy joint in the exhaust and started it.
    Aaahhhhhhh the sweet sweet sound of a spooling garrett ball bearing turbo
    https://www.youtube.com/watch?v=jg1L...e_gdata_player
    96 GQ coil/Cab
    08 G6eT
  3. #2343
    Damn dude that whistle is insane! Way louder than mine. I love the Garrett turbos, can hear them winding down through both the snorkel and the exhaust once you shut off the engine.
    Sent from my iPad using Motorculture mobile app
  4. #2344
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Had mine serviced and had the tappets adjusted. Surprised that the rest of the vehicle is in good nick other than the rust. Found out the last mechanic used shell rimula oil and it turns gluggy apparently?
  5. #2345
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    Installed dawes and needle valve. Got the heavy duty spring option for the dawes. Had it running up to 25psi without going into limp. Have it set at a safe 17psi with spikes only up to 18psi under heavy load in second gear. WOW what a difference it has made to the car. After having the injector pump done and driven home it was still driving as it always did, slow and sluggish but now the acceleration is 5h1t loads better!! with the set up I blocked the EGR aswell the other week so my EGT's are down quite a bit too, going up to 250 where it would be 300-320 before.
  6. The Following User Says Thank You to meh For This Useful Post:
    threedogs (5th September 2013)
  7. #2346
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    Got myself a roof rack high lift jack holder !
  8. #2347
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Gave the beast a bath and vaccum
  9. #2348
    Western suburbs of Melbourne
    11 Post(s)
    started researching suspension lift kits again. bloody hell that's a nightmare.
  10. #2349
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Fitted some 9" spot lights.
  11. #2350
    11 Post(s)
    Quote Originally Posted by Parksy View Post
    Nice looking troll. Very clean looking.
  12. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    Parksy (6th September 2013)
