Played with the dawes after fitting new tigged IC had so much boost, spiking at 25 and sitting on 20 foot flat.
I've backed it right off and re did it and the needle valve, yet to go for a spin but think its spot on as in
10psi @ 2000 rpm, only 5 psi ATM causing higher than normal EGTs. Have to pick up some stuff in the morning so I'll fine tune as I go.
