Page 104 of 1465 FirstFirst ... 102103104105106 ... LastLast
Results 1,031 to 1,040 of 14641
  1. #1031
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Commodore is playing up!!! Backfiring its litte a!s off and stalling!!!
    I want my Patrol back!!!
    Leads loose or arcing from that little metal cylinder around the engine end?
    Coil packs?
    Maf sensor?
    IAC valve?
    Hello from Under Down Under!
  2. #1032
    Clean maf sensor
    Disconnect battery for an hour to reset ecu
    Check tps
    Go over all earths
  3. #1033
    Aug 2011
    North West Tas
    56 Post(s)
    Clean maf sensor
    Check tps
    Go over all earths
    Shut up, you owned a ford....
  4. #1034
    And you drive a pooncy commy everyday! Do you wear a UNIT singlet and a jet pilot cap? Sit Real far back in the seat and just lean to one side Real far and then just one hand on top of the steering wheel?
  5. The Following User Says Thank You to Winnie For This Useful Post:
    BigRAWesty (3rd September 2013)
  6. #1035
    Aug 2011
    North West Tas
    56 Post(s)
    Why didnt you ring to to say you were coming for a visit!?
  7. #1036
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Coil packs?
    Maf sensor?
    IAC valve?
    Clean maf sensor
    Check tps
    Go over all earths
    yep all that to do, going to do new spark plugs and leads first as I don't know it the pugs are set at the correct gap for LPG and i don't think the leads are for LPG either. Hit n miss as to when it backfires but still makes me jump when it goes off! *L*
  8. #1037
    Aug 2011
    North West Tas
    56 Post(s)
    ohhhhhhh on gas too. Does it do it on both fuels?
  9. The Following User Says Thank You to taslucas For This Useful Post:
  10. #1038
    Feb 2011
    Shed
    45 Post(s)
    And you drive a tough as guts commy everyday! Do you wear a UNIT singlet and a jet pilot cap? Sit Real far back in the seat and just lean to one side Real far and then just one hand on top of the steering wheel?
    Yes...............
  11. #1039
    Aug 2010
    17 Post(s)
    Pretty sure it just on gas and mainly when you take your foot of the accelerator then put it back on ( giving it a little bit )
  12. #1040
    Kicking it out around the roundabouts in the wet? LMAO sorry Toddie =]
