Page 1 of 15 123 ... LastLast
Results 1 to 10 of 142
Thread: 3.0lt GU Patrols - Grenade Facts
    Thanks to YNOT for the detailed response on why people call some 3lt diesel motors "Grenades".
    There are heaps of threads on other forums on the subject (sounds like you found some of them), but the early ZD30 engines fitted to GU series 2 had reliabillity issues and developed a reputation as a grenade that could go off with out warning at any time. Series 3 onwards are more reliable, but it still pays to take a few precautions to make sure they stay reliable.
    Most engine failures seemed to be caused by fouling of the Mass Air Flow (MAF) sensor with crank case ventilation vapours, causing the sensor to send incorrect air flow data to the engine computer. This results usually in over fueling, raising Exhaust Gas Temperatures (EGT's) to dangerous levels, which melts pistons and damages other engine components. Air flow into the cylinders can also be reduced (by Exhaust Gas Recirculation (EGR) carbon combining with the PCV oil vapours building up in the inlet manifold. Reducing air flow to the cylinders makes the over fueling situation worse.
    There is a series of modifications (engine saver mods) that can be done to eliminate the causes of these faults.
    As Nisspat said, it's usually the 4.2 owners that call them grenades.
    Tony
  2. The Following 2 Users Say Thank You to YNOT For This Useful Post:
    hunter64 (2nd September 2012), Stevelb21 (26th June 2015)
    Aug 2010
    Wellington NSW
    What are the mod's ? PLEASE
    Banned
    Quote Originally Posted by old briney View Post
    You'll find lost of info & step by step in this document posted in the DIY section the this forum. Link provided below.
    http://www.nissanpatrol.com.au/forum...rence-Document.
    Paul
  5. The Following User Says Thank You to patch697 For This Useful Post:
    benno (30th January 2012)
    Apr 2011
    Nissan Patrol Ref Doc
    Quote Originally Posted by patch697 View Post
    Paul
    Have tried to download the above but can't - message says I have to have 25 posts before I can access this document? Any suggestions?
    Welcome to the forum mate, I suggest you get 25 posts under your belt.
    Put up an intro in the introductions section, post up your rig in the members ride section, join in some general chats, welcome some other new members and you'll have the manual in no time.
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Thats correct
    sit back join in get to know a few people submitt some pics
    your 25 posts will be up in know time
    heck you might even want to stay longer
    May 2011
    Is there anybody out there who is having usual 3.0ltr issues with the Series 3 and onwards. Looking at 2007/2008 model ute.
  10. #8
    Welcome to the forum wnicko, when you get a minute drop by the introductions and tell us a bit about yourself.
    Series 3 onwards are very reliable with very few recorded engine failures. As with any make or model there have been isolated failures but they are few and far between. I have read a few reports of the CRD (Common Rail Diesel) engines being a bit heavy on fuel.
    Tony
  11. #9
    May 2011
    Ownerr or vehicle
    Thanks for that Tony.
    A bit about myself, well you wouldn't believe it but (you might) i have always owned LANDROVERS.
    Now don't turn off your computer because i am just about to buy a 07-08 cab chassis 3.0Ltr CRD Nissan.
    Why, because Landrover stopped making cab chassis in 1998 when they made the TD5. Shame.
    Not keen on going back to free wheeling hubs, constant 4 wheel drive (cental diff) is the go. Never had any issues with Landrovers, i've had seven and built a Discovery. There are lemons amongst all makes.
    Hope to have as good a reliability record from Nissan as i did from Landrover. Sometimes it's the owner and how they drive and maintain machinery.
  12. #10
    Expert teleman's Avatar
    May 2011
    Montrose
    I was under the impression that the grenading ZD30 problem was fixed in the GU series II. can anyone please confirm??? cause mines has had no issues.
    2001 GU series II 3.0 TD.
    2" lift
    Dual Battery System
    ARB Snorkel
    Awesome car!!!!
