Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: O/d button in auto
    Hardcore 2TROLLFAM's Avatar
    Nov 2011
    Chuwar - Ipswich - QLD
    Out to Lake Moogerah (near Boonah) watching a friend, Brad & Talia play on the new jetski (our friends) so will experiment with the button on the trip home
    NISSANS Rulz .... "Amelia" the 2006 4.2ltr Patrol Ute & "Seamus" the 2008 3ltr Patrol Wagon
  2. #12
    There is another button near ashtray, this holds the revs longer,
    But as you said have a play when its safe to do and press a few buttons
  3. The Following User Says Thank You to threedogs For This Useful Post:
    2TROLLFAM (31st August 2013)
  4. #13
    Nov 2011
    Is that the one that says power/hold??
  5. #14
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Quote Originally Posted by 2TROLLFAM View Post
    Yea that's it. I have mine in power all the time, it holds the gear for longer and will kick back easier.
    O/D switch is for towing and hills. Overdrive shouldn't be used when towing (o/d off). The switch is also good for long hills and over taking, when driving in od the auto can cool down a lot, but with it on and accelerating it can get hot quite quickly. Eg. Driving at 100km/h with it on cruising, call it 5th. Accelerate to go up a hill, drops back 1 gear, call it 4th. Now with od on in 5th the torque converter is locked, not generating much heat. In 4th it's unlocked at that point, which generates a lot of heat. BUT with od off, it locks the torque converter in 4th which now won't create that much heat.
    I'm sorry if that doesn't make any sense, I'm not very good with words.
    Lachlan
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  6. The Following User Says Thank You to lhurley For This Useful Post:
    2TROLLFAM (1st September 2013)
  7. #15
    Aug 2013
    Perth
    Off when overtaking
    I find myself Turning Overdrive off whenever overtaking on the highway, especially taking doubles nad triples which are long and take time to get around, gives it a boost right off the bat.
    Other than that, my overdrive is always on around town etc.
  8. The Following User Says Thank You to Stampy For This Useful Post:
  9. #16
    Every now and then I'll press it [OD] just to slow down a tad instead of hitting the brakes.
    I've found lately I've been driving it manually as is cogging down for corners, seems my fuel figures have
    improved driving like this. But I'll try the power button for a tankfull and see what happens
    Towing my Tub trailer I'll tend to take off in the lower gears and press the OD button at 80 plus KPH
  11. #17
    Nov 2011
    Tried it out coming home yesterday & had to run back out to Aratula today and played - makes a huge difference ..
    Towed my trailer over to mums & OMG you need to use those buttons to get anywhere - especially when merging onto the highway ...
  12. #18
    Pakenham Victoria
    My previous two Patrols were both autos and I rarely turned it off. Made no difference towing or not. Autos are pretty smart and can work out when to up shift or down shift all by themselves. That is why you buy them isn't it?
  13. The Following User Says Thank You to Wazza_66 For This Useful Post:
    2TROLLFAM (2nd September 2013)
  14. #19
    brisbane
    If you had an auto temp gauge you would see the diffrence it makes
  15. The Following User Says Thank You to megatexture For This Useful Post:
