Who's manuel ??? lol
Didn't realise you weren't, but now you are.
Good on ya John.
Macca
threedogs (30th August 2013)
good on ya john for jumping onboard mate!
Welcome John
Any forum member discounts??????????????????? *LMAO*
I'd be happy with an intro!
Onya John, good quality stuff.
Hi TD,
What are my options on a GQ for front recovery points? I'm running an ARB winch bar if that has an impact.
cheers,
Drew.
I have a replacement for the drivers side OE hook,
or if you want to use two you'll need to remove the
bulbar and make a plate to slide inside chassis,
Mudski fitted two using this method.
The plate also has provision for one of those 4.7t black hooks with the spring steel keeper
Edit reason is you only have captive nuts on the drivers side
