Results 1 to 9 of 9
Thread: tb42 clutch, which one to get?
    Nov 2012
    hey guys
    so the clutch in my tb42 shorty finally went the other day so time to stop putting it off and get a new one, just wondering what everyone recommends
    ive been looking at the exedy heavy duty and the safari tuff clutch
    anyone have any other suggestions?
    its got 35s and gets put through its paces on the weekends on all sorts of terrains
    ive also heard the td42 clutch fits and its tougher?
    cheers
    Aug 2013
    Wollongong nsw
    The td42 clutch fits and has a stronger clamping force .
    Hardcore
    central coast nsw
    Question.
    Is the TD clutch leaver/fork stronger than the TB's one.
    or are they identical parts.
    Just fitted safari tuff, personally, like the feel but pedal is very short on stroke before it take up.
    forum comments are, this is normal.
    local brake & clutch who I bought it off recons not the case and will diagnose shortly.
    let you know how it turns out.
    but no earlier than next week me recon.
    oh and don't forget to get flywheel machined, very important.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  4. The Following User Says Thank You to Robo For This Useful Post:
    Joshshorty (2nd September 2013)
    Aug 2013
    Wollongong nsw
    Clutch forks look the same .
    Hardcore
    central coast nsw
    Quote Originally Posted by 98patrol View Post
    up date YES THEY ARE ACCORDING TO NISSAN FAST , so that cant be an issue.
    Patrol Guru
    Apr 2011
    Melton
    Sunbury brake and clutch do a td42 for $320
    Nov 2012
    Ended up getting a safari tuff last week just gotta get around to getting it in now
    Let us know how you go robo
    Cheers guys
    Patrol Guru
    Apr 2011
    Melton
    Are you pulling the box or the motor.
    While you have the box or motor out replace the rear seal, and the welch plug (the one behind the fly wheel at the towards to top of the motor) - mine was nearly rusted though when I done it
    I pulled the motor as I have a gantry - and did not want to be under the truck trying to lift the box - very heavy.
  10. #9
    Nov 2012
    I'm pulling box out, I'll just use the hoist and gearbox jack at work
    Had planned on doin the rear main while I was going, also rebuilding the starter motor with all new bearings and the slave as well
