Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 102
Thread: Reverse camera position. GU Patrol...
    Thanks Hooking up the trailer is easy , but vision to stop you running over things and god forbid ppl is more what I want.
    I re read the thread a few times and most just want to see towball, I;ve sent some emails
    to try and get and answer, thanks again , Might make a alloy housing and using double sided tape
    stick camera inside housing to the centre position of rear doors up the top, sort of like a cup pull on an old drawer
  2. The Following User Says Thank You to threedogs For This Useful Post:
    PMC (24th August 2013)
  3. #22
    176 Post(s)
    Just seeing the towball & the front of your trailer won't help to avoid backing the trailer over something you'd rather not.
    Up high, or another camera on the back of the trailer!
    Whether you mount it as you suggest , or inside the window depends on which you want to wipe. Both will get dirty or covered in rain. They are useful, but not perfect. I use mine as rear vision for driving, but only as an addition to the side mirrors, because in crap weather the camera view can be pretty degraded. If only used for reversing I guess a handy rag for wiping the camera or window would be the go, before hitting reverse gear.
  4. The Following User Says Thank You to Cuppa For This Useful Post:
  5. #23
    My rear wind deflector is U/S ATM so I might mount it there over the weekend and see how it goes,
    easier to run the wires too, If it proves ok I'll go buy a new one and fix it more permanently, I'll be using rivnuts
    to fix camera to the Perspex, then some holes and cable ties to hold the wires neat, Should get great vision from that height
  6. #24
    Bumped,,,, as I know a couple are waiting on an out come, Anyway rigged it up and powered the screen and camera via a cig socket.
    Plugged it in and found the best spot was in the middle of the rear wind deflector, it showed me the complete back of the Patrol
    Plus about 8ft out, During the week or tomorrow I'll put some rivnuts in the deflector to secure the camera, some convoluted tubing and a few cable ties
    and the outside is done, I can pick up power from the small lift out panel in cargo area.
  8. #25
    brisbane
    Mounting it up high wont allow you to see enough behind a trailer unless its a simple box trailer that's empty, if you want to see behind your camper or caravan I'd put a camera on it. Mount the one on the car where you need it for every day driving and like cuppa I've got mine running off accessories best way IMO, when I'm listening to the radio I can't see it but a cd/ or ipad I can see the camera all the time while driving then when you hit reverse it comes on overriding everything.
  9. The Following 2 Users Say Thank You to megatexture For This Useful Post:
    PMC (24th August 2013), threedogs (24th August 2013)
  10. #26
    never thought of putting one on the rear of my camper, maybe above the numberplate
    On Ebay you can buy the replacement rear number plate light bracket that has camera on it,
    but closest I can find is Pathfinder quaisi or similar need to source one for the GR not the GU
  11. #27
    brisbane
    If you put one on the camper you could just get a wireless unit so there's no cable to get damaged
  12. #28
    Hardcore
    Coffs Harbour
    Quote Originally Posted by megatexture View Post
    stuck mine up under the handle above the licence plate on the small door then its got a bit of a roof on it also
    G'day Mego,
    I have got a photo to show us please!
    Regards,
    RLI
    The halls been rented the bands been paid, time to see you dance!
  13. #29
    Hardcore
    Coffs Harbour
    Quote Originally Posted by happygtu View Post
    The factory position on mine is to the passenger side of the number plate light on the small barn door.
    It isn't too bad with the factory camera, and gives you great vision, but you can see it is off centre. If I was installing it myself I would try to mount it to the drivers side of the handle on the same door, as it is closer to the centre of the vehicle.
    Mic
    G'day Mick,
    Can you take a photo of your set-up to show us please!
    Regards,
    RLI
  14. #30
    Hardcore
    Coffs Harbour
    Quote Originally Posted by bad055 View Post
    I placed mine just above the roof gutter with a plumbing elbow over it to protect it. its in the center so it gives a good view and looks good with the cover over it. it ment drilling a hole in the roof for the wires to go but im happy with that. its a neat patrol but if ya cant drill and cut things on it, ya not gunna go bashing through the bush in it are ya? and whats the point in having a 4x4 if ya too scared to get a few scratches on it? lol. but it give a great view and its outa the way up there.
    G'day bad055,
    Regards,
    RLI
