Hey macca. So what shocks do you recommend?
I sometimes wonder why we're not keen to name names. Is that just pc or us the a risk in doing that?
Sent from my GT-I9305 using Tapatalk 2
GU IV 2006 Snorkel 225 Driving Lights Dual Batteries Factory Bar Awning Rear Drawers Part NADS (so far)
All Done , arms and legs are saw, but have 2 inch now .......lol
97 GU Ti 4.5 on lpg , uhf icom Pro400, Garmin GPS Maps, HD-Lukas Dash Cam with gps tracking. Snorkel , I-Max 12000lb Winch , Twin rear light bracket on wheel carrier for light & uhf antenna,Draws unit, Electric Cargo barrier, HID headlights kit, LED Light Bar, 2 inch lift with HD King springs and Monroe Gas Magnum TDT 4WD Shock Absorbers, BS Dueler 697 Lt 285/75R-16 .
They look like crap mate!, they look better coverd in mudgo get em dirty. Good to see you fitted them yourself also.
altech (24th August 2013)
Kast, I would not recommend any brand or model of a brand as all our needs are different.
The high end Konis are supposed to be the best for outback rough tracks but how do the perform in the bush near the coast?
I have ToughDogs, Ralph on the front and BigBore Adjustable on the rear. At $ 550.00 a pair they are expensive. I met a guy on the ABH in 2010 who had done 300000klm on out back adventures and swore by them.
On our recent trip a 75 series had BlueMax that are supposed to be made in the same factory as or are rebranded ToughDogs. It pogoed on any whoop-de-doos or moguls and one did fail.
Mine did not behave like those and are still working fine.
They may well be made in the same factory. You could use a comparison as the base Commodore and the SS out of a GMH factory, different specs.... that was what my previous comment was about.
Macca
Kast (24th August 2013)
Hi Guys, just got back from getting Alignment done, Service guy said I should have off set castor fitted , I posted my wheel alignment results , Can you tell me if his right ? he Quoted $ 120 for the rubber one that go to 4 deg plus the same for fitting and alignment again, at the moment car drives great , even at 100ks , not wobbles or dirfing to left or right, all good :-)
If its not wandering all over the road I wouldn't bother
Hi guys, been 5 days now with my new 2inch lift kit, finding that there a nosie in the left front passager side , just a sight knock only when the road dips in the road , maybe thinking that I haven't put spring in candle right , need help ? regards Alex B
Maybe find somewhere to flex it up to help seat it right.
altech (28th August 2013)
