Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: TD42T performance additions - where's the sweet spot?
    Being the question is about a TD42Ti you won't be ale to chip it. A 3" mandrel bent straight through exhaust including the dump pipe and a decent Dyno tune will set you back about $1000 if you shop around. You will drive in with about 65rwkw and drive out with 95 to 100rwkw.
    You will need a variable boost controller too and I recommend a Pyro Gauge too so add another $500 for that but a great place to start.
    Once the above is done you have a very good starting platform that will work great and be ready for any future mods you want. Hi flow the turbo for $1800, replace the turbo for $2500. You already have an 11mm pump so pump upgrades should be down the list.
    Have fun. Every mod gets a grin
  2. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    Mikees (23rd August 2013), SonOf (25th August 2013)
  3. #12
    22 Post(s)
    You can chip a td42ti as it is electronically contolled.
    You could get a gtx 2863 with a bit of change from 2K
    96 GQ coil/Cab
    08 G6eT
  4. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Mikees (25th August 2013)
  5. #13
    That's interesting, I have read that before but have not been able to find a chip?? Who does one Ben? Be keen to investigate if you can point me in the right direction.
  6. #14
    22 Post(s)
    Pretty sure its uni chip.
    96 GQ coil/Cab
    08 G6eT
  7. #15
    Patrol Freak gaddy's Avatar
    redlands
    Search 4.2l chip on here , nissannewby comments on here . Sorry don't know how to link
    Steve
  8. #16
    Quote Originally Posted by gaddy View Post
    Steve
    http://www.nissanpatrol.com.au/forum...2285-4.2l-Chip
    Yes as Newby states though there is No Plug n Play unit made for the TD42Ti. You'd need to adapt what is on the market. I spoke to the guys at Uni Chip at the 4x4 show a couple of years ago and they looked at me blank!
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (22nd August 2013)
  10. #17
    You get that a lot don't you...
    Adelaide Hills, SA.
    There was some talk from the mob that offer the $12k upgrade of the inclusion of a performance module in the tuning side in addition to the custom pump and the rest. I think it was referred to as a 'PD'
    Is anyone using a TD05 16g large turbo in a touring/towing application?
  12. #19
    Patrol God Stropp's Avatar
    38 Post(s)
    ive bought a 16g large from RLI but havent fitted it yet as i want to do the intercooler and manifold at the same time, pm paul he will give you the lowdown or nissanneby.
  13. The Following User Says Thank You to Stropp For This Useful Post:
