Results 1 to 10 of 16
Thread: lsd operation
    Nov 2010
    lsd operation
    hi,
    I've been looking for a difinitive way to test the LSD on my GQ, but have found conflicting information. My diff has the LSD sticker on and both wheels turn the same way when off the ground and 1 is rotated. I've tried jacking up 1 wheel and trying to drive it off the jack, but the wheel in the air just spins. I tried applying some brakes, but it still just spins. Yet, I tried it on the road with one wheel in some really slippy mud and the other on gravel, it locked up so well that the tyre on gravel actually span as well as the one in the mud. I got out of the mud easily with road slicks and 2WD. Any ideas what's going on?
    I've also order some redline 75W/140 (with the friction modifier already in) as I'm not sure what's in the diff currently.
    cheers
    1981 Nissan Patrol MQ SWB, 3.3TD, West Melbourne.
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by boggy2006 View Post
    hi,
    cheers
    Definitely change the oil first mate to ensure it is LSD oil. Sounds like it is grabbing under load though - when you had it in the mud. Happy to be wrong (generally am) but I thought the LSD needed load to engage and hence the concept of just jacking it up and spinning the wheels is not an absolute failsafe test.
    Nov 2010
    thanks, that's what I was thinking, but when off-roading under full articulation with a rear wheel off the ground, wouldn't you want it to lock up to transfer power to the wheel on the ground?
    Oct 2010
    It only does that partially though - hence the words "limited slip" - it's not a locker, and will only attempt to grab for a short period without traction. My meaning was I thought you have to test it under load, being load coming from the drive shaft - power/torque as such. Again, could be wrong, but not sure jacking it up gives it any "load" as such and it may just act as a fully open diff. Something to do with how the diff alters the torque being delivered to the wheels under load to ensure the wheel with traction can still keep spinning - but again, is limited so will eventually release and act like an open diff.
    Tony, how did I go? Have I failed? Am I relegated to the back of the class again? LOL!!!
  5. The Following User Says Thank You to Bigrig For This Useful Post:
    boggy2006 (15th February 2011)
    Banned
    As a rule a good tight LSD would perform better than you described so im thinking it may need a freshen up & I have also been told that getting one wheel only spinning up can cause damage to the LSD as well & you should lift out when this is the case to prevent damage but Tony is more up to speed on these thing so I'd wait for him to post up some info for you before righting it off on what I've said.
    Nov 2010
    found this;
    To appreciate just how ‘limited’ the slip is, try the following test. With a vehicle fitted with a rear LSD, place an axle stand to lift one of its rear wheels off the ground and then chock both front wheels with a brick. The LSD will not provide enough torque to drive the vehicle over the brick (vehicle obviously in 2WD). If a diff lock was fitted then the vehicle would drive forward easily.
    In many offroad circumstances the traction avaliable to the rear wheels is similair and the LSD can control any wheelspin. However as soon as there is a large difference in traction ie. one wheel off the ground, there is no way a LSD will have any beneficial effect
    from here http://www.pps.net.au/4wdencounter/a...difflocks.html
    so A++ for Bigrig and Patch!
    Oct 2010
    well that's a first!! Staying on topic as well!!!! LOL
    Till now anyway ....
    Feb 2012
    mine had has that problem now i know how to fix it thanks guys
  10. #9
    22 Post(s)
    From memory a nissan lsd requires about 17Nm to engage and it hold to a couple of hundred Nm. If you are having a problem with it disengaging you can also use the left foot break trick
    96 GQ coil/Cab
    08 G6eT
  11. #10
    Hardcore
    central coast nsw
    Quote Originally Posted by Bigrig View Post
    Ok off topic, have seen straight 140w recommended, what's the feeling here.
