Results 1 to 10 of 10
Thread: Water injected head????
    Jun 2011
    Tasmania
    any proper clues as to all the water pipes going into the head? is it just for cooling?
    Cheers Mark.
    Yes for cooling mate, if you give Brett a call at 4wd Obsession in Melton Victoria he is running a Turbo TB42 with that exact setup in a Cut down comp car. Very tidy unit. He'd be happy to fill you in.
    Jun 2011
    Tasmania
    awsome mate, cheers for that
    Expert Frontbumfab's Avatar
    Got a patrol in the back yard with that work done. Worth swapping the head onto my turbo one?
  5. #5
    Quote Originally Posted by Frontbumfab View Post
    Absolutely if you can do the work!
  6. #6
    Yeah no worries with doing it. Done it to many times already haha. So it does help heaps? Ill have to put t pieces into the head and run the line along the head. Not much room for all them pipes with the turbos.
  7. #7
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Not to be confused with actual "water injection" which is where water is atomised into the combustion chamber.
    Hello from Under Down Under!
  8. The Following User Says Thank You to taslucas For This Useful Post:
    Frontbumfab (17th August 2013)
    It helps in continuous high output so like race 4wds etc where they spend most of there life flat out. It allows a more uniform flow to the head in turn helps with cooling it the above described conditions.
  10. The Following User Says Thank You to nissannewby For This Useful Post:
  11. #9
    Yeah its just to get water flowing better to stop cracking and what not
  12. #10
    Sep 2011
    adelaide
    18 Post(s)
    Hi Guys
    Its very old technology, Offenhauser and many race engines ran a cooling system which used individual tubes to even water circulation around each cylinder.especially to the rear cylinders. Offenhauser for those interested , their block and head were cast as one piece eliminating the use of a head gasket. these motors were very successful at Indy and also speedway.
  13. The Following 2 Users Say Thank You to pearcey For This Useful Post:
    Frontbumfab (17th August 2013), taslucas (17th August 2013)
