Results 1 to 8 of 8
Thread: wate to air intercooler upgrade on a zd30
    Beginner onlyme376's Avatar
    Apr 2013
    gracemere
    Wink wate to air intercooler upgrade on a zd30
    hey i have upgraded the pathetic excuse that nissan calls an intercooler on my 06 3.0l
    the original was also leaking so i did some measuring and head scratching and then purchased a water to air kit from votion industries on ebay. after relocating the power steering cooler, the fuel filter and the solenoid vaccum control valves for the swirl control and nozzle control everything fitted in very neatly
    see the pictures attached
    2006 gu iv 3l auto st-s wagon
  2. The Following 2 Users Say Thank You to onlyme376 For This Useful Post:
    AB (15th August 2013), P4trol (12th September 2013)
    Looks great mate. Nice fit up. Looks like a bit of stuffing around to get from the turbo to the heat exchanger? Would have been a bugger. Did they only sell that style of exchanger? I run a frozen boost W/A cooler on the GQ and they had many options available to achieve the most direct root.
    Have you got a link to the seller on eBay?
    Have you noticed much change in temps or performance?
    I am on the iPad and can't really make out what you have done in the last pic of the bonnet scoop?
    Well done.
    22 Post(s)
    Nice. I have an A.R.E water to air and its great! What type and where did you mount your pump?
    96 GQ coil/Cab
    08 G6eT
    Apr 2013
    gracemere
    hi thanks
    link to ebay seller http://stores.ebay.com.au/Votion-Inc...p2047675.l2563
    the pipe work wasn't to much of an issue it's using the original turbo outlet pipes straight into a 3" to 2.5" reducer the oulet side i bought a 2.5" piping kit and cut to fit with a 2.5" to 2.25" elbow to the inlet manifold
    I haven't got to check the temps yet but midrange torque is better the torque converter now locks at 60k's where it never used to
    the bonnet scoop i had to cut a bit out to allow clearence for the boost sensor, I'm thinking of blocking the middle part of it as it is now only cosmetic
    Apr 2013
    gracemere
    Hi
    the pump is a bosh oem as used on supercharged mustangs ect and i mounted it on the pasenger side inner gaurd behind the aircleaner
    Patrol Freak trekster's Avatar
    Nov 2012
    Coffs Harbour, NSW
    Very nice I like it.
    1998 GU RD28T: RIP
    Hello 2012 GU CRDZD30
    Beginner scott.a.green's Avatar
    Aug 2013
    Looks nice mate. Easy enough to relocate the filter etc?
    Apr 2013
    gracemere
    Hi
    yeah fortunatly it's an auto so the fuel filter went on an aluninium bracket on the fire wall where the clutch would be and the ir a resistor there that is mounted to the front of that bracket as well to act as a heat sink and the two control soleniods are mounted onto the old fuel filter bracket so it all went into place nicely if it was a manual there would have been a bit more head scratching for the filter
    and so far seem to be getting around another 100k per tank of fuel and the engine is runnig much nicer so onto the next lot of mods i guess
