Results 1 to 9 of 9
Thread: Monkey with a spanner
    Beginner Getafix's Avatar
    Aug 2013
    I have been meaning to get my hands dirty for a while and start doing mods myself. The best place to start I figure would be to put my self under 2.5 tonnes and swap out the panhard rods. Only problem is I would not know what to look out for.
    For example - would I need to have the car on Jack stands? - Research has taught me this is a 'Yes'
    But apart from that, I have not found anything else.
    I was wondering if there was anything in particular I needed to look out for?
    Also, the reason I am changing the panhard rods is because of the dreary death wobble. Having my trusty neighbourhood mechanic swap out the bushes would cost me as near as makes no difference as a brand new set of adjustable panhards and some much needed know how (Also I am looking at a 3" lift, so I see this as stage 1). I was looking at a set of ToughDog Adjustables, but am open to suggestions.
    Bitumen...Another waste of public funds
    2002 GU III A/T Gold Grenade
    Apprentices Rule!!! Punderhead's Avatar
    Nov 2011
    Toowoomba, QLD
    Hi getafix
    If you are just swapping out the panhards, and leaving the rest of the suspension in place, he only things you will need are the correct spanner and socket, and a mate.
    Just park on flat level ground and swap them out one at a time. Undo the bolt and the nut, and pull off the old panhard. Then put one end of the new panhard loosely in place ( the side with the stub, as opposed to the side with a bolt) lift the panhard to almost in position, then have your mate lean slightly on the side of the car to push it sideways until the bolt slides straight in. Tighten up the nuts. Then double check. It even pays to use locktite.
    My mate forgot this step and the bolt fell out while he was driving. Luckily doing only 15kmh he looked like an idiot!
    But this has always worked for me.
    Good luck with the mods.
    Cheers!
    GO HARD OR GO HOME!!!
    My rig HERE http://www.nissanpatrol.com.au/forum...Moneypit-89-GQ
    WARNING: Towballs used in a recovery can and DO KILL people!!!
  3. The Following 2 Users Say Thank You to Punderhead For This Useful Post:
    Getafix (11th August 2013), Rustyboner81 (13th August 2013)
    Legendary happygu's Avatar
    Changing out the Panhards is fairly easy, and there is little chance of anything happening if you do one at a time, as the weight of the car is still suspended on the springs and also held steady by the opposite end, and it is unlikely to suddenly spring sideways on you.
    You will find the Jack Stands on the chassis are really only for the safety side of things, and are of little help in actually fitting the panhards, unless you are lifting the whole vehicle a little higher to get underneath, however, it always pays to be on the safe side.
    Once you undo the nuts, the bar just slips off fairly easily.
    Slip the old one off, and then slip the new one on, after getting it roughly to length with the old one, and then adjust if required at this stage after the nuts are on.
    Mic
  5. The Following User Says Thank You to happygu For This Useful Post:
    Aug 2013
    Thanks guys, sounds like fun.
    Also, what manufacturers should I be looking at? I have not really heard people put a whole lot of emphasis on brands but it doesn't hurt to ask
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Quote Originally Posted by Getafix View Post
    Superior Engineering. Hands down the best. Plus they have free freight.
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
    Superior Engineering for me too....
    Mic
    Quote Originally Posted by lhurley View Post
    X2. Big fan mate.
    If you are doing this alone without a mate close by then I'd recommend jackin the chassis up and put it on jack stands so the weight of the car is on the stands and the wheels are on the ground. If you set it up like this it simply can't move when you take off the old panard and is preset to the correct position for when you fit the new one.
    The Panard holds the body centre over the diffs, if the body is sitting on the springs when you take the panard off there will be nothing but balance stopping it from shifting. Shifting even 10mm to one side you will not see until you try to fit the new one that you have setup the same length as the old one and now you need a mate to give the body a push sideways while you try and refit it.
  10. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Getafix (13th August 2013)
  11. #8
    Aug 2013
    thanks guys, will have the panhard rod shipped over. Hopefully, that should get rid of the wobble. If not, I believe inspecting swivel hub shims and king pin bearings would be in order.
  12. #9
    X2. Big fan mate.
    I have done it alone using a ratchet strap. I put the strap on before removing panhard then it all stayed in place.
