Hi guys, beware I installed all the correct gear and do every 5ks oil changes,
Light can on with acceleration, went to Nissan for computer check up nil faults recorded.
Its the senor they said change it still the same problem. every time I back off to idle oil pressure drops to 2-5 psi max 28 when hot @ 3000RPM, nil noise or sludge in sump.
Oil pressure test engine fault found oil pump and conrod bearings and front and rear bearings need replacing, this is a 03/2007 common rail ZD30, so don't believe its only the early models that are susceptible to oil pressure loss, 170ks now $4600 later thanks Nissan computer gurus.
