To try and explain how to read legislation, you would need to read associated case law alongside it. How it was written and how it was meant to be interpreted will be subject to legal challenge. New legislation is always open to interpretation (by both the prosecution and defence). District and Supreme Court case law (decisions) are binding in all courts, decisions and interpretations by Magistrates (local) are not binding in any court, that includes other Magistrates courts. If you were to fight it all the way through the court system, ie all the way through to a higher court then it would become a binding decision. That said, if the powers that be don't like the way that the umpire ruled then there would be an amendment to that legislation and the process starts again.
To answer the question, can they be mounted above the roof line? You need to read between the lines and interpret it your way but be prepared to justify your position.
This is the way I understand the below points.
• The lamps should, as far as is possible, be installed symmetrically in pairs to the front of the vehicle. ( Front ie bulbar, not no the roof which is roughly centre of the vehicle)
• If lamps are not fitted as pairs (e.g. one, three etc), they must be fitted to the front of the vehicle, symmetrically about the centre. (Front as above and in the middle)
• The lamp/s must be installed in a way that the light produced does not cause the driver of the vehicle discomfort either directly or by reflection. (Open to interpretation as to driver discomfort, but any light mounted on the roof would have some degree of reflection)
By the way when I fit my LED light it will be on the roof.
