Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 61
Thread: Diff oil smell
  1. #41
    Cheers mate, I'll make sure there's a couple of coldies in the fridge
    My folks went to the Google Play Store and all they got me was this lousy Motorculture App!!!!!!!
  2. #42
    Legendary Alitis007's Avatar
    15 Post(s)
    Cheers mate, very much appreciated. So besides loctite, socket set and a hammer, any other tools I may need? Got chassis stands from Repcos sale the other week so all good there............
    You might need an open ended 17mm spanner to stop the caliper slide from turning while you are undoing the caliper bolt if you decide to remove the caliper and cradle in 2 pieces. A flat screw driver to push the piston back like Rusty said is a winner too, just don't push it too far coz you will push the fluid out of the brake master cylinder and you'll have to poor water of it straight away coz brake fluid peels paint. Putting the wheel under the car like TD said is a very smart idea, coz you will have the jack stand under the diff if for any reason that slips having the wheel under the rear door will make sure you don't wear a wheel arch for a hat
    If there is anything else make let me know so i can walk you thru ....
  3. The Following User Says Thank You to Alitis007 For This Useful Post:
    Clunk (1st August 2013)
  4. #43
    Cheers big ears , will be sure to ask if I run into problems. Rusty popping over so should be ok.
  5. The Following User Says Thank You to Clunk For This Useful Post:
    Rustyboner81 (1st August 2013)
  6. #44
    Patrol Freak Rustyboner81's Avatar
    Perth
    I'll bring my trolley jack, stands and impact. Will probably be a 20 minute job all up.
    Sent from my GT-I9305T using Motorculture mobile app
    '92 (MIGHTY) GQ ST 3.0L Duel Petrol / LPG, 2" Pedders Suspension Lift on 33x12.5x15 BigHorns
    Lukey 2.5" Performance Exhaust with Extractors, snorkel
    Auto Lokka In The Front, Duel Batteries, Stiff Deep Dish Steering Wheel,
  7. #45
    Expert Kast's Avatar
    Nov 2012
    Sydney, NSW
    Let us know how it all pans out lads. ..
    Sent from my GT-I9305 using Tapatalk 2
    GU IV 2006 Snorkel 225 Driving Lights Dual Batteries Factory Bar Awning Rear Drawers Part NADS (so far)
  8. #46
    Quote Originally Posted by Rustyboner81 View Post
    Trolley jack would be good, I've only got a bottle jack at the moment. I've got stands though Russ.
  9. #47
    Perth
    Cool
  10. #48
    Big thanks to Russ for all you done today, another champion bloke.
    Found a definite leak once the wheel was off, so off came the calliper, then the rotor, pulled out the axle and found a small cracked on the Inner seal now replaced and no more diff oil smell.
    Pictures to follow once friggin MC decides to play ball again
  11. The Following 4 Users Say Thank You to Clunk For This Useful Post:
    Alitis007 (4th August 2013), MudRunnerTD (3rd August 2013), threedogs (3rd August 2013), Woodsta1704 (3rd August 2013)
  12. #49
    OWheel off and there we have signs of leakage.
    Calliper and rotor off more signs of leakage.
    Look carefully and you'll find the small offending split in the inner seal........ Cost a whole $8 for a replacement one from Repco.
    Shaft
    Little syringe and Straw device Rusty came up with in order to repack the bearings with grease after the diff oil was cleaned out of them.
    (A PIC SHOULD BE HERE BUT THIS CRAPPY APP HAS CRAPPED ITSELF YET AGAIN AFTER THE THIRD REINSTALL THIS EVENING)
  13. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    Alitis007 (4th August 2013), Woodsta1704 (4th August 2013)
  14. #50
    15 Post(s)
    Nice work mate! See it wasn't that hard after all aye?
