Page 24 of 50 FirstFirst ... 2223242526 ... LastLast
Results 231 to 240 of 498
Thread: Outback Ideas Recovery points
  1. #231
    Expert Shaun 4x4's Avatar
    Secrets
    Got my front and rear points today, I only ordered them on Sunday and I'm in perth. That pretty dam quick indeed.
    Cheers.
    I should have mentioned I wanted the rear point to be black.
    Shouldn't cost much to get it powder coated.
  2. #232
    Just spray paint it shaun....
  3. #233
    177 Post(s)
    OK I'm in the market for a set of these front recovery points. Got my set for my Navara last year from tjm Coburg. The bloke who makes them was unwell at the time and took a while to get a set. Does tjm still carry these ??
    Sent from my Samsung S4 using Motorculture app
    Pretty sure TD doesn't outsource his parts to retailers.. You probably bought a rip off copy.
    Best to either call him or email (both in first post) to discuss your needs.
    Owner of
    Westy's Accessories
    Nah TJM Coburg Started me off with advice etc, I have a few loyal shop Aust wide who have stuck with me ,
    With all the Operations I've had,
    @ Hodge I'm always "un well" more so lately. and Coburg should have some, They are Genuine .
  6. #236
    177 Post(s)
    Far out I should read more. Had no idea you made these mate. Will drop by tjm and grab a set.
  7. The Following User Says Thank You to Hodge For This Useful Post:
    threedogs (31st July 2013)
  8. #237
    I'm there a fair bit so keep a look out for my Patrol, [RE Avatar]
  9. #238
    Secrets
    Do you think the paint will hold up ok?
  10. #239
    Yeah it should be ok, a lot of Qld guys spray them black as local police pull over anything with red hanging off them, so I was told
  11. #240
    Secrets
    Just finished painting the rear point flat black. Looks great.
    Are the original bolts back there good enough to reuse?
    Also not sure if its in this thread but the bolts on the factory recovery point. WTF?
    A 19mm socket relates to an m12 bolt, well every bolt I've had but not these they are bigger.
    What size are the front bolts and where can I get some from on a Saturday?
