Results 11 to 20 of 25
Thread: Brake upgrade
    nah you will fit a 15. i know a few blokes fitting 15s to a GU front end. as long as its not the 4.8 which are bigger again you'll be fine.
    The Brakes on the GQ after swapping to GU Diffs and brakes is Insane! Love it.
    Avo (5th August 2013)
  3. #12
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    Yes it would be tight Damaverick has 15" rims I have changed mine to 17" which appears to have ample clearance.
  4. The Following User Says Thank You to Pezzer For This Useful Post:
    BigRAWesty (29th July 2013)
  5. #13
    Quote Originally Posted by Pezzer View Post
    You'd be able to crawl threw that gap... Lol
    Owner of
    Westy's Accessories
    Jun 2013
    Gold Coast
    Fri/Sat calliper swap.
  7. #15
    How did you go mate?I'll be doing my brakes soon the more info on what to choose the better.
  8. #16
    Jun 2013
    Gold Coast
    Had a crazy weekend so have not started them yet but will this week.
  9. The Following User Says Thank You to Pezzer For This Useful Post:
  10. #17
    Jun 2013
    Gold Coast
    Okay started the brake swap, removed the Patrol Twin calliper and Rotor first I pulled the wheel first followed by the Auto hub carefully removing not to disturb the hub innards. Then disconnecting the brake line I removed the 2x 22mm bolts holding the calliper, followed by the cir clip retainer in front of the auto hub mesh gearing. the Patrol has a bearing retaining ring where there are 2 locking screws remove these and then slide the Hub off the stub axle being careful of bearings and rear seal.
    Over to the Maverick same steps as above but Manual Hubs, bearing here is retained by conventional retaining nuts behind a locking shim, using a punch knock the first nut then remove the locking shim then tap off the second nut slide the hub off as above.
    Both callipers have the same bolt PCD so all good there, the only stumbling block I found was as small 2.5mm ridge running inside the Maverick (1990) hub, this prevented me reinstalling the bearing locking ring, so to get around this I split hub from rotor on both vehicles and swapped them over.
    Refit reverse of dismantle, re bleed brakes job done.
  11. The Following User Says Thank You to Pezzer For This Useful Post:
    Sherro (10th May 2014)
  12. #18
    Jun 2013
    Gold Coast
    Bought new slotted rotors to match up with the twin piston callipers, should arrive today will take a few pics before the rim goes back on.
  13. #19
    Jun 2013
    Gold Coast
    pics of the twin piston callipers and new slotted rotors fitted to the Maverick
  14. The Following 3 Users Say Thank You to Pezzer For This Useful Post:
    mal555 (26th August 2013), MEGOMONSTER (13th August 2013), threedogs (17th September 2013)
  15. #20
    Beginner mudbug's Avatar
    Sep 2013
    Hay Pezzer been watching your break mods will be doing this my self ,have callipers no rotors yet will I need master cylinder doesn't look to hard of a job looks good
