Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Front wheel bearing maintenance
    Hi guys
    Has anyone done a DYI procedure for servicing the front wheel bearings with hub lock for a manual GU 08 DX. Is it something one can do at home requiring no special tools?
    AJ
    Thanks Tony
    AJ
    Tony sorry to bother on a Sunday night, on the GU, I have taken the two screws out, the washer falls out. But which part is the hub nut, does the nut have internal thread or and external thread?
    AJ
  5. #5
    This is where I am up too. See photo attached. ImageUploadedByMotorculture1374993900.835125.jpg
  6. #6
    475 Post(s)
    Quote Originally Posted by Ajwood View Post
    AJ
    The washer behind that outer washer that has the screws in it is the hub nut. Use use a pin punch on the hole and go righty tighty or lefty loosey.
  7. #7
    Thanks mudski
    Should it be so hard to loosen. I have it fair clout?
    AJ
  8. #8
    I got it undone. I reckon it was too tight. Should it be just tight enough to get rid of play in the bearing?
    AJ
  9. #9
    It depends how much preload was put on the bearings last time the bearings were apart. Shouldn't take too much force to undo.
  10. #10
    AJ
    I run the hub nut up until it touches then tighten a few degrees further. Spin the hub a few times to settle the bearings then loosen off and do it again.
    You may need to adjust the hub nut back or forwards a few degrees so it lines up with the holes in the lock nut, your call whether you tighten or loosen.
