Results 1 to 10 of 19
Thread: Reverse Camera Install ideas
    Expert Limmy's Avatar
    Cool Reverse Camera Install ideas
    Hi Guys
    I'm looking to get a stereo with the works . screen , dvd , blue tooth , camera .
    I want the reverse camera option also . Good for parking and especially for the misses
    Questions
    What are some mounting positions for reverse camera ?
    How to run the wire from camera into the car ?
    Are there types of Cameras I should avoid ? I heard there some that don't work well at night
    Is it hard to wire to reverse ? so the camera turns on automatically
    Thanks heaps !
    don't buy the gps wireless, think most mount above number plate and point camera at towball.
    having same dilemma as I want to run two cameras.
    its getting wires to the front I'm stumped on maybe under carpet along the sides
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Limmy (28th July 2013)
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    For a camera in the dash id run wires under carpet under the sides, or under the roof lining along the sides.
    Having the camera activate on reverse there should be a 12v wire input on your Screen/DVD system that you need to tap into the reverse light wire. Id have a look at which one goes to the reversing light and see if you can locate the same color at the front of the vehicle
  5. The Following User Says Thank You to meh For This Useful Post:
    brisbane
    I've put mine up above the licence plate like 3dogs suggest and I found it to be the best place, and I ran my wires under the carpet and in the step wells under the plastic trim. And connected mine so on with accessories
    I've got 3 cameras 1 reverse 2nd is mounted on the snorkel pointing forwards ( for my vertically challenged wife to see in car parks) and 3rd one is in the car mounted in the front overhead light pointing backwards to see the kids. With a knob to switch between them.
    @ Mega how did you get wires into cargo area seeing they have those rca ends on them??
    take it you had a video switcher to get from camera to camera. I want one rear and one watching rope spool onto winch.
    brisbane
    Had to take the lining off the small barn door and there is a hole large enough to feed the wires inside right next to the handle ( i think i had to remove the licence plate lights also to get acess) then I ran the wires into the door and in the car through the stock rubber wire loom near the hinge .. It was a pain in the ass .
    Also note once the lining is removed from the door you will see a plastic lining, make sure you put it back or bull dust will enter your car via the barn door ... And alot of it !
  9. The Following 2 Users Say Thank You to megatexture For This Useful Post:
    juzzs8 (5th April 2016), threedogs (28th July 2013)
  10. #7
    Oct 2011
    Essendon
    Quote Originally Posted by megatexture View Post
    Hey Mega,
    Mate, I'm also curious as to how you set up the switching for the various cameras.......
    Tip tip tip......tap tap tap....
  11. #8
    Expert scotty83's Avatar
    Apr 2011
    Hillcrest, QLD
    I have just finished this on my gu i will try to finish my write up and pic and get it up here for you.
    ScottyB Motoring
    Scotty B | Take it Off Road or Take it Back
    3.0L GUIV 2005 - TIG Welded Intercooler, NADS, Redarc Dual Battery, Additional rear power socket, 2" Lift (Ironman constant load foam cell), Electronic Trailer Brake Controller, Steel Bullbar, 12,000lb Winch, UHF
  12. #9
    I have a video switching Thingy, that allows me to choose which screen I want to view.
    Was only cheap and does 3 cameras, I'll grab a pic, haven't used it yet but think its the right gizmo
  13. #10
    brisbane
    I've made my own switch using one of these from jcar http://www.jaycar.com.au/productView.asp?ID=SR1216 I looked around and could only find units like 3 dogs shows but wanted something compact that I could mount on the dash,
    It was a bit finicky but the main thing is to make sure as little of the centre wire is exposed as the outer wire is a shield blocking your signal from signal interference.
    Ill post up a pic of the finished product when the wife gets home
