Results 11 to 20 of 28
Thread: lift kits
    Quote Originally Posted by Drewboyaus View Post
    Isn't it now within the new national guidelines now that you can run 33's and a 50mm lift without engineering?
    Tip tip tip......tap tap tap....
    The national thing was a huge flop and went nowhere...
    SA is 50mm max, and 7mm tyre.. Yep, you read that right...
    Owner of
    Westy's Accessories
    Advanced Woodsta1704's Avatar
    Jun 2013
    Perth WA
    I went with Tough Dog Foam cell shocks and the 200kg front and rear springs. Check out the link below for WA if that's where you are (interesting stuff is in section 4):
    2002 GU 3 Lt Patrol Wagon. On Board Air, ARB Front Air Locker, 2"Tough Dog Lift, Rear Air Bags, Tracklander Roof Rack, IPF HID Spotties, K&N Air Filter, Cargo Barrier, 3" Dominator Exhaust, Titan Drawers and much more.
  3. The Following User Says Thank You to Woodsta1704 For This Useful Post:
    sporter (27th July 2013)
  4. #13
    Patrol Guru paulyg's Avatar
    Ballarat
    Vic is 75mm total lift, tyres + springs.
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
  5. #14
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Do we have new national guidelines *LMAO*
  6. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    BigRAWesty (27th July 2013)
  7. #15
    Aug 2010
    17 Post(s)
    Quote Originally Posted by YNOT View Post
    Technically you are correct but you would have to be extremely unlucky to be booked for a 2" lift and 33's on a Patrol.
    Yes extremely unlucky Tony, but the salesman has every reason 2 say he won't install them if he believes it 2 be illegal
  8. #16
    Legendary happygu's Avatar
    Quote Originally Posted by paulyg View Post
    Is that the current regulations now, or something that is proposed?
    Mic
  9. #17
    Aug 2010
    17 Post(s)
    I'm not the smartest cooking in the class
    But from my understanding from both VIC Roads modification guide and infrastractures NCOP11 Section LS Tyres Suspension Steering ( VSB14 )
    50mm is still the current Total limit above factory ride height
    But sometimes ( most ) I just don't understand what is written in front of me so I am probable wrong
  10. #18
    Expert oddkid82's Avatar
    Apr 2013
    Quote Originally Posted by happygtu View Post
    Mic
    That is the current regulations.
  11. #19
    Oct 2011
    Essendon
    13.3.1 Option 1 on page 7 of the VicRoads guide:
    "This option allows a combination of suspension lift and the fitting of larger diameter tyres that results in a total lift of up to 75 mm without the need for the testing and certification normally required by VSB 14 for lifts above 50 mm provided the following requirements are met."
    What it does call into question though is fitting combinations of springs and shocks that are not part of a matched kit from a single manufacturer......
  12. The Following User Says Thank You to Drewboyaus For This Useful Post:
    NissanGQ4.2 (27th July 2013)
  13. #20
    So as I read it for you guys, you can 'legally' install a 50mm spring lift and the either 25mm in body or tyres to give an over all of 75mm.. Or any other combination..
    Owner of
    Westy's Accessories
