Page 205 of 1057 FirstFirst ... 203204205206207 ... LastLast
Results 2,041 to 2,050 of 10566
  1. #2041
    Never been aware that there was left and right springs.
  2. #2042
    Patrol God Stropp's Avatar
    38 Post(s)
    yeh mate drivers side is slightly longer to make up for the constant weight in the vehicle and they tend to sag that little bit to give it a level look after a while.
  3. The Following User Says Thank You to Stropp For This Useful Post:
    Rustyboner81 (24th July 2013)
  4. #2043
    Expert Kast's Avatar
    Nov 2012
    Sydney, NSW
    Shes only got an 2.75 beaudesert and snorkel, standard tyres. It wasn't a proper dyno as such, he just had her on rollers under load and was monitoring noises and stuff under bonnet and turbo. She's going back there for valves, catch can and once EGR is blocked she'll get a full dyno tune.
    Still, she goes so well now, I still can't believe how much difference exhaust alone made. I actually now can't wait to have the bar back on and go for a good proper drive to feel her across all gears.
    Hodge, did you fit the zorst and if so how easy was it? Was looking at a beaudesert for mine.
    Sent from my GT-I9305 using Tapatalk 2
    GU IV 2006 Snorkel 225 Driving Lights Dual Batteries Factory Bar Awning Rear Drawers Part NADS (so far)
  5. #2044
    How much is a Beaudesert sytem btw?
  6. #2045
    Nearly finished diff lamination.. Duck Its solid now...
    Hopefully finish the pumpkin brace tomorrow, then start rebuild.. Yay..
    Owner of
    Westy's Accessories
  7. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Parksy (25th July 2013)
  8. #2046
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    That looks excellent westy! Nice job. Looks stiff!
  9. The Following User Says Thank You to Parksy For This Useful Post:
    BigRAWesty (25th July 2013)
  10. #2047
    She won't bend in a hurry, that's for sure..
    Owner of
    Westy's Accessories
    Nov 2012
    Sydney, NSW
    Mudski, they quoted me $1135 for aluminised steel and $1800 for stainless. add $25 for packing and $100 for freight to wa.
    That's with a free flow muffler.
  12. #2049
    @ Kallen did you weld in the small piece at the knuckle, about size of match box,
    stops knuckle bended after some big air,
    just saw it .
    Also you could weld on a pumpkin protector ???
    Did you use GU or GQ diff housings ,paint with POR15 awesome on diffs
  13. The Following 2 Users Say Thank You to threedogs For This Useful Post:
    BigRAWesty (26th July 2013), Parksy (26th July 2013)
  14. #2050
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Just got back from dropping it off 2 the smash repairers In a few weeks time the paintwork on the roof and bonnet should look smick as Hopefully the windscreen breaks when they pull it out so I can get a new 1
