Results 11 to 20 of 23
Thread: Wheel bearing problem
    Patrol Guru
    Apr 2011
    Melton
    You will require Grease and Rags and about 10 hours
    I use toilet paper - roll per side
    Took me around 4 hours per side - including a beer or 2
    yep - you will need grease and a few tools.
  2. The Following User Says Thank You to GQ TANK For This Useful Post:
    Ferret (5th August 2013)
  3. #12
    Advanced Ferret's Avatar
    Jul 2012
    Lmaoooo yea not a Problem I think this ones gonna be for the local mechanic lol
    mk patrol sd 33turbo diesel, bullbar, roof racks, driving lights, efs 2 inch lift, 35" Federals, Rear qtr chop.33" led lightbar..
  4. #13
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    Just get a quote first. It would not be a cheap exercise thats for sure. I would be thinking somewhere around the $1k mark
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  5. The Following User Says Thank You to lhurley For This Useful Post:
  6. #14
    Expert Blownlc's Avatar
    Werribee Vic
    I bought my swivel hub rebuilt kit from patrolapart for $185. It's actually a pretty simple process to change everything.
    When you pull each component out, lay it on a piece of board in the same way and order that it came out.
    Clean as you go on the dismantle. And grease as you go on the reinstatement.
    It is a little time consuming, but very rewarding when you realise how much money you have saved yourself!
    It's not as hard as sounds. Good luck.
    LESS YAP YAP, MORE TAP TAP!!
    http://www.nissanpatrol.com.au/forums/image.php?type=sigpic&userid=8495&dateline=1347611  053
  7. The Following User Says Thank You to Blownlc For This Useful Post:
  8. #15
    Jul 2012
    Yea I'm done the mechanic wanted 500 for the instal not chance I was gonna pay that so I went ahead and done it all my self took longer then I thought I'm left with 2 seals and I was just gonna ask is there 2 seals inside the diff am I gonna gonna have to pull those axles out again and then drop the diff centre to get them 2 seals ... Cause it's not like other I have Seen the axle seals suppose to be at the end off the housing don't if that make sence.... Unsure were to find the axle deal thanks boys
  9. #16
    Jul 2012
    And a quick question... Instead off the old locking nuts for the bearings I was hearing that maybe a set of gu lock nuts just love the design not a chance in the world for them buggers to come loose any done this or no if they are same thread size to mk .... Thanks again
  10. #17
    If the seals are small, about a 50c piece size they will axle seals. Located just behind the hub. Axles need to be removed of course but not the centre. If you have already filled the diff up with oil and there is no leaks. Leave it.
  11. #18
    Jul 2012
    No seal in there it's weird confused shatterd I can't upload pics on here due to using this forum via phone ....
  12. #19
    Just so others can see. Here is the seal in question
    Goddammmmmit!!! Bloody motorcraputre! Hang on.
    I tapped that app
    Worst App ever!!! Anyhow, this is what the seal looks like from the pic I was trying to upload from my phone but MC is too dumb to let me.
    Ermagerd! Now I have apparently exceeded my upload quota here!!!!
    see this bloody link.
    http://www.quicksales.com.au/ad/fron...ol-g60/4793298
  13. #20
    Jul 2012
    I'm all done just finished in late thanks to use all for the help and effort use put in I got em done and they were hiding ... The diff centre come out and they were right there .... Thanks mudski for letting me brake your balls cheers
