Decided to go for a drive today.
* Forest just off Smith St is private property owned by Hanson Concrete.
* Little Nerang Dam Rd was closed with a SEQ Water gate. The gate says closed 6pm to 6am each day. I was there 1pm Sunday and it was closed. Might try again later.
* Found a spot at Mt Nathan thanks to 4x4earth.com.au. You drive up a driveway into the bush. I won't be there for long though as a new housing estate is building there. Steep climb to start with and then about 1/2 way up it's real rutty. It then started pissing down so reversed down the now wet slippery track and turned around. Will give it another try in the dry.
That's as far as I got today but 99% of it was road driving just seeing what's still here and what isn't.
