Page 194 of 1057 FirstFirst ... 192193194195196 ... LastLast
Results 1,931 to 1,940 of 10566
  1. #1931
    Expert florix's Avatar
    Casino
    Just pulled the radiator...
    Attachment 31468
    Bit hard to tell but has mass collapse and corrosion of the fins..
    RIP radiator. 23yrs..
    Not bad really as this is only the second time its been pulled out..
    Owner of
    Westy's Accessories
    Not bad! 23 years! Get a PWR they are brilliant!
  2. #1932
    Yea not sure. Won't be alloy that's for sure.. but I dug a bit deeper, water pump is fine, but thermostat was locked solid open... So a new high flow for that one, will look into the radiator..
    Owner of
    Westy's Accessories
    84 Post(s)
    Check the new thermostat in boiling water, before you fit it. I had an after market one for a falcon which was stuck shut, I can't remember the brand though.
  4. #1934
    Casino
    Owner of
    Westy's Accessories
    Yeah I hear that alot. But I did read there is a way to repair them. Plus in order to damage mine will take a lot.
  5. #1935
    Can't seem to find a high flow thermostat for early model gq. Only 97 onwards
    Owner of
    Westy's Accessories
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Fitted a new sports steering wheel. Feels great and not loose like the original. While fitting it this little guy decided to run up the back of my neck and head. Flicked it on the dash, squashed it and it fell down the vent. Bugga!
  7. #1937
    84 Post(s)
    Why do you need a high flow, Kallen? If the water runs through the radiator too quickly, it won't cool down enough. Are you doing any major changes to the engine which will require extra flow?
  8. #1938
    177 Post(s)
    Scored a new factory deck, the one that they fit to 2010 Patrols and onwards and bluetooth and USB, only to find that the wiring harness won't plug in. Bugga!
    178 Post(s)
    Bought & fitted some weathershields from Supercheap. They had just one pair (driver/passenger) in stock, & the driver side one had been taken out of it's wrapper & was missing the label which attaches to the wrapper. On this basis I asked the slightly post pubescent nymphette behind the counter if I could buy it at a reduced price. She checked & the computer said yes. Price had already been on 'special' at $44 & she apologetically said "I can do it for $39". Not sure what it was about how she said it, but I thought it worth asking if she could also do the fully packaged passenger side one for the same price. Blow me down, she agreed straight off. So two weathershields for $78 saw me walk out the store with a smile.
    Fitting them was a piece of cake, they attach with VHB double sided tape. I warmed the weathershields in front of the stove for a while, & warmed the door with a hot air gun before & after fitting, because the temps outside were a bit chilly, & apparently VHB tape prefers temps over 10 deg.C, & preferably above 20 deg.C. Took car for a drive. With window fully down at 100kph there is a small amount of draft, just enough to move my hair a bit, but with the window half down you still get air, but nothing blows around. Very happy with the purchase.
    Cuppa
  10. The Following 3 Users Say Thank You to Cuppa For This Useful Post:
    Stropp (11th July 2013), threedogs (11th July 2013), Woof (11th July 2013)
  11. #1940
    Was your fly up LOL . They are not as large as I thought they'd be, great driving window down rain ,hail or shine.
    Nothing like letting the follicle flow in the breeze. FYI my slimline do nothing except maybe stop a bit of sunshine
