Hi Swampy.
The double row Aurora's are a 3w LED. The single row Aurora's are a 5w LED.
By the way, that price includes shipping.
Thanks,
Paul
				Hi Swampy.
Thanks,
Paul
				Hi Megomonster.
The 3w double row Aurora's have 14400 lumens and the 5w single row Aurora's have 19600 lumens.
So obviously a difference however the double rows at $600 are amazing value.
Cheers,
Paul
MEGOMONSTER (14th April 2013)
			Thanks for the reply, are you able to get the 5 watt double row? And if so how much can you do them for? Thanks
				Just arrived new range of LED light bars.
LIGHT BAR 14" 60 WATT 6 X 10 WATT CREE LED'S COMBO BEAM $135
A high light output Light Bar at an affordable price
10W X 6 Cree LEDs 5400lm
Colour Temperature 6000-6500K
Working Voltage DC 9V-32VDC
Current Draw 4.26 amps at 12V. 2.2 amps at 24V
Operating Temperature minus 30 to + 50 Degrees C.
Waterproof grade IP67
Body material : Diecast Aluminium
Lens material : PC (polycarbonate)
Beam angle 8 (Spot) and 120 degree (Flood) = Combination
LED life 30,000 + Hr
Totally electrically Protected against RFI/EMC interference (Radio Noise)
Bolts in Stainless Steel
Double Insulated Cable
These produce a massive amount of light and are virtually indestructible.
Can be mounted in a multitude of positions with brackets supplied.
LIGHT BAR 22" 100 WATT 10 X 10 WATT CREE CHIPS COMBO BEAM $175
10W X 10 Cree LEDs 9000lm
Current Draw 7.1 amps at 12V. 3.6 amps at 24V
LIGHT BAR 30" 140 WATT 14 X 10 WATT CREE CHIPS COMBO BEAM $349
10W X 14 Cree LEDs 12600lm
Current Draw 9.94 amps at 12V. 4.98 amps at 24V
LIGHT BAR 42" 200 WATT 20 X 10 WATT CREE CHIPS COMBO BEAM $435
10W X 20 Cree LEDs 18000lm
Current Draw 14.2 amps at 12V. 7.1 amps at 24V
LIGHT BAR 50" 240 WATT 24 X 10 WATT CREE CHIPS COMBO BEAM $499
10W X 24 Cree LEDs 22000lm
Current Draw 17 amps at 12V. 8.5 amps at 24V
Contact me to place an order and I will over ride the price on our website and also send your order out freight free.
				Hi,
What kind of housing are these in?I have seen a few in mining applications up to 7 inch and they weigh more than my 22inch 5w as they have a large heat sink and housing. These dont look any where near the size, how well do they dissipate the heat.
Ben
96 GQ coil/Cab
08 G6eT
				Hi Ben and thanks for your enquiry.
The housing is made of diecast aluminium. There is a picture of the dimensions of these lights on our website with each 10w lightbar however the body is 76.39mm high and 86.5mm deep. The pictures do not give a good indication of the size of these lights.
They are not small like a typical 5w lightbar housing. There are some small 10w lightbars available however our manufacturer is staying away from this design at the moment after testing some and the housing becoming very hot. LED's will last a very long time providing they are kept cool and the heat generated is dissipated appropriately hence the bigger housing.
$$ for lumen output they are great.
Cheers,
Paul
			Just ordered a set from Paul for my Prado (don't hurt me). 2 x 10" & 1 x 20" both single row Aurora 5w led bars. Paul was extremely helpful and answered many of my questions promptly.
Will post a some photos of the setup once it's all in!
DX grunt (12th July 2013)
