Results 1 to 10 of 14
Thread: Moneys cylinder head lube
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    Moreys cylinder head lube
    Hi , bought a shorty on dual fuel and noticed a container on the firewall with a vacum feed containing cylinder head lube, at $22 a liter and the rate of use is this a nesassary item?
    Running gas it's necessary keeps some lube up to the top end which gas can dry. Better for your valve seats too.
  3. The Following User Says Thank You to nissannewby For This Useful Post:
    Pezzer (26th June 2013)
    84 Post(s)
    G,Day, Pezzer. Some people swear by cylinder head lube when running lpg, but it is a personal choice. I have just helped strip down a V6 with a burnt valve, which had not had the lube bottle fitted. I used to use a product called Flash lube.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    Jun 2013
    Gold Coast
    I watched it today and it seemed to be using too much so now I found a screw that when turned slowed the flow, if it lubes like 2 stroke oil it should not need so much through surely.
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    No shouldn't use alot. I did a quick google and it seems people have it set at a drip rate of 1 drop every 6 seconds.
  8. The Following User Says Thank You to Parksy For This Useful Post:
  9. #6
    Jun 2013
    Gold Coast
    I am at about 1 to 10 secs.
  10. #7
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    1 to 10 is fine. You can get flaslube for about $17 a litre.
    1999 GU 4500 dual fuel
    Il dado è tratto
  11. The Following User Says Thank You to NP99 For This Useful Post:
  12. #8
    Patrol Guru
    Apr 2011
    Melton
    Im about to fit a kit to mine (had it on the MK) - auto barn has the lube and kits.
  13. #9
    Feb 2013
    Broadford VIC
    Quote Originally Posted by GQ TANK View Post
    Repco has 20% off in July.
    Il dado è tratto
  14. #10
    Advanced senility Brisat's Avatar
    Dec 2012
    Dakabin QLD
    It's Morey's and 1 drop every 8 secs is best. it's a lead replacement system for older engines and is used to help keep the valve seats in reasonable condition.
    The mind is still making contracts that the wallet can't afford
    1993 Maverick TD 42 mit einem Turbolader, triple battery setup with 2 twin battery units & solar panel, 21/2 & 3 in exhaust, 5 dash mounted gauges, 55 ltr beier frig/freezer, broken winch, UHF & HF radios hf auto antenna, rooftop tent, portable satellite tv system and the ship hanging on the back [4.2 m runabout with 50 johnson] happy hour
    Dakabin 4503 QLD
    WARNING: Towballs used for recoveries,can and do kill people and damage property and also scare the shit out of people standing next to the car
  15. The Following User Says Thank You to Brisat For This Useful Post:
    threedogs (10th August 2013)
