Results 1 to 10 of 20
Thread: Project LS GQ Ti
Threaded View
  1. #18
    Jan 2013
    The sump comes with all the bits, pickup shouldn't be hard to mod, when I do it ill document it all so others can go down the same path if I can't heat it and bend it to the position I need I'll get it cut and shut by the local hose and fitting mob here. I can't see there being $450 worth of modifying there so I'll still be better off and I'm sure people will appreciate a write up on how to do it.
  2. The Following User Says Thank You to Brendan260RS For This Useful Post:
    Thirsty (26th June 2013)
