Results 1 to 10 of 14
Thread: A rapid 2 second shudder
    Expert Pezzer's Avatar
    Jun 2013
    Gold Coast
    Question A rapid 2 second shudder
    Whilst driving on the Hway I get a shudder through the steering like I have gone over the edge lines on the Hway the ones that make a noise. I last for 1/2 seconds the goes for random intervals only to do the same again?
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Which one are you in the SWB MAV or the LWB GQ???
    Jun 2013
    Gold Coast
    The SWB Maverick.
    Patrol Guru Morton's Avatar
    Sydney West
    could be bearings or a bush is failing, look at the control arm bushes first, then bearings & kingpin bearings
    2002 3L GU Patrol, 2" lift, 33's, snorkel, dual battery, sliders, DVD, bluetooth
  5. #5
    Patrol Freak liftlid's Avatar
    Nov 2010
    6 Post(s)
    does it always happen at the same speed? every time I get a wobble at 90kph I know I've got bushes wearing out. for me its usually the top panhard bush.
  6. #6
    Jun 2013
    Gold Coast
    No the speed when it happens is varied, and yes it is an auto. I did notice that when towing the Lwb Patrol home the MAverick struggled up hill.
  7. #7
    Jun 2013
    Gold Coast
    Oh yes the bushes are new urethane ones throughout.
  8. #8
    Are all the rims tight. Jack front off the ground and check free play, up and down and sideways
  9. #9
    Aug 2010
    17 Post(s)
    Quote Originally Posted by Great Southern Camping View Post
    Speed will vary - if the lining is gone, it'll can even attempt to lock up when stationary and cause spluttering like it wants to stall (mine did). Usually worse when it's cold at the onset of the problem.
    I would be thinking along the same lines as Scottie hence why I originally asked if it was the Mav or GQ, I just assumed the SWB Mav was manual, sorry I should of asked if it was auto or manual to start with.
  10. The Following User Says Thank You to NissanGQ4.2 For This Useful Post:
    Great Southern Camping (25th June 2013)
  11. #10
    Jun 2013
    Gold Coast
    When its cold the power is down until it has run for 5 mins.
