Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Compressor with external tank build.
    Spot on.. you have it in the power line between switch and main power relay so it overrides the switch once up to pressure. Then the master switch cuts all power, and the main relay does its stuff..
    While my trol is off the road I'm fitting an endless air setup. Unsure if ill run a tank as the pressure and supply capability of the air con pump is insane...
    Ill be going a 150psi cutoff, but the pump is capable of 400+ psi and even higher flow, so I should be aired up in under 5 mins.. love it..
    Owner of
    Westy's Accessories
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    This is Image is the best to get an understanding, I've just used a different kind of pressure switch.
    [IMG][/IMG]
  3. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    The BigFella (21st June 2013)
  4. #23
    The only problem with that wiring diagram is that it is a Switch to Earth (negative switching circuit) and I am not a fan to be honest.
    I would be way more inclined to install a positive switching circuit so on a worst case basis you cut supply and there is no way you compressor can find an earth to keep running.
    I would put your switch and your pressure switch into 86 for direct control of your relay.
    My2c
  5. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (17th August 2013), The BigFella (21st June 2013)
