Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Compressor with external tank build.
    Expert sil3nt_dr3ams's Avatar
    Mar 2013
    Most of the system is already built from my last patrol.
  2. The Following User Says Thank You to sil3nt_dr3ams For This Useful Post:
    threedogs (18th June 2013)
    Nice mate. How big is that tank?
    Sent from my TWD_MID using Motorculture mobile app
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    Looks good man, once you are finished all these mods on yours you are more than welcome to stay at my joint for a couple of weeks, I will supply all meals.
    (Solid meals not liquid.)
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
    Mar 2013
    Quote Originally Posted by krbrooking View Post
    Lol mate, gee no beers?
    Tanks 8 litres.
    @ Kallen check onboard air for all the different tank sizes,
    Available in alloy or steel, multi ports as used for Doof doof cars
    Had a very nice 600 x150 alloy 6 port job in other 4x4
    BigRAWesty (19th June 2013)
    Mar 2013
    Have alook at this, remove all the electrics.
    Go to the suppercheap website and have alook at the Blackridge Air Compressor - Direct Drive, 1HP. 8litre tank 80$
    Quote Originally Posted by sil3nt_dr3ams View Post
    http://www.supercheapauto.com.au-/-Blackridge-Air-Compressor-Direct-Drive-1HP
    Is that 12v or 240 unit? cheap pressure vessel, pressure switch and pressure control valve with reg though for sure!
  10. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (19th June 2013), mudnut (19th June 2013), threedogs (19th June 2013)
  11. #8
    Only cheap if all the bits are low voltage..
    Owner of
    Westy's Accessories
    Oct 2010
    Old Bar, NSW
    With all the bits left after taking the motor and compressor off you have to be in front I reckon. The pressure switch will handle the current through a relay but not the compressor at 12VDC.
    Drain, pressure switch, fittings, regulator, gauge and tank for $80 sounds good. Most probably from that cheap manufacturing country but it will do far a while.
    Add a 12VDC relay and 12VDC compressor plus a few hoses and fittings could be a winner.
    Looks like Silent has used the same stuff in his DIY project here, not sure but looks very similar.
    Macca
  13. The Following User Says Thank You to macca For This Useful Post:
  14. #10
    Yea fair call.. cheapest tank I could find is around the $70 mark so yea it is a good option..
    Owner of
    Westy's Accessories
