Hey Mate,
That's an interesting one. I've just had a chat to our suspension manager and:
If they leafs on the trailer are 50mm wide? Most trailers are; then we'll have one that matches in width, which is a good start. After that the load plus spring is 310mm long, in order for it to fit you would need the space between the back of the diff/Axel and the shackle or mounting point at the rear of your leafs to be at least 310mm long, ideally longer.
Now we make no guarantees that this will work perfectly without having someone take a look a measure up the suspension, but if it meets the above criteria then I don't foresee you having an issue. Also they should be $125 for the set.
SOLD with a heavy heart but gone to a nice young fella
