Remove the tin plate that is held on via the axle studs & clean & inspect all the seal faces if you can catch your finger nail in a groove worn by a seal you will need a SPEEDY SLEEVE to repair it (google SPEEDY SLEEVE to see what it is used for) Fit the plate back loosly & clean up all the bearing carrier
With the new bearings i myself dont think they come with enough grease packed into them so i always repack them with high temp bearing grease
I also take the new outer bearing race & put it back in the box by itself & put it into the freezer while im repacking the bearings & cleaning all the parts
