Results 1 to 5 of 5
Thread: Rear compartment cover.
    Advanced Superoo's Avatar
    Fremantle. W.A.
    Smile Rear compartment cover.
    Hi all,
    Is there anyone that knows of a rear compartment cover blind that pulls out.
    I have noticed on my GU Series 3 there are some holes and clips in the rear that could be used for something like this.
    Mine is a ST model, Im wondering were the blinds standard in the top of the range model?
    Cheers.
    03 Patrol Series 111 GU 3.0 Turbo Diesel,3" Ironman lift,Ironman shocks,33" Wild trac A/Ts,Rock sliders, Lightforce 240 spotties,Rhino Pioneer Rack,40tl Engel fridge,GME uhf aerial, Safari snorkel and upgraded recovery points.
    I've always wondered about these clips and holes too...
    Advanced Monty_e's Avatar
    Brisbane, Northside
    That makes three of us?
    2003 GU ST ZD30 Auto
    Pre NADS: Pyro & Boost Gauges, EGR block plate, Catch-can, Multi Stage Boost Controller (Dawes valve) & Needle Valve ordered!
    They are to hold seat belts or seats out of the way. How expensive is that mini roller door stuff you see on some utes.
    Other than that cut a holland blind to size, or cut a piece of canvas to size and affix using ute tie down thingies, {Yes BA its a part}
  5. #5
    Apr 2013
    Mount Nasura
    They call them a Cargo Blind, my Xtrail had one, I do believe I have seen a photo of a GU with one.
    2008 GU ST Bog stock and no smoking barrels!
