Hi guys,
This week, my gq (td42) at:
1.Yakıt pompası değişimi (remove the inline pump, VE pump wear)
2.to td42, turbo installation did
3.and new clutch....
Ex : Lr 110"def+ Lr100" def+Tyt WX80 Land Cruiser+MB 406 Ünimog doka : Jawdrop:
New: 1992 Nissan GQ y60 safari (td42) : Hpfredgeorge1:: Bananarock:
Turbo fıttıng....
new clutch
Wish I could say I fitted EGT and boost gauges...but can only say drilled a messy hole in my dump pipe.
Was trying to tap a thread in for the fitting but stuffed it up. I'll have to find someone Tuesday morning to weld one on.
The rest of it's almost done with no probs though.
Did you get it sorted.??
Also going to cut some Laser plates to mount Fire extingishers in cab.
The BEST Position is either in front or beside the driver.
Reason being its the FIRST thing to grab in the advent of a fire.
No point mounting them say on your cargo barrier, or cargo area
Will be very cost effective, plus save you drilling into floor.
Been thinking on this for a while.
I'm still waiting for my IC to arrive thinking Tuesday everything is Tuesday
Replaced the clutch, (pulled the donk) as I wonted t replace the exhaust manifold gasket.
Found the rear welch plug nearly cored though.
Did 388 k's on the new long range tank and the gauge only moved to just below full![]()
Finally got The Q off road and dirty
Stropp (9th June 2013)
Gave the Q a nice wash after a dirty weekend in the Howqua Hills.
Tip tip tip......tap tap tap....
